rear wheel bearing out again 62kmiles - TCCoA Forums
post #1 of 3 (permalink) Old 04-26-2004, 08:52 AM Thread Starter
Question rear wheel bearing out again 62kmiles
I just put my 01 Lincoln LS rims on and painted the calipers. The car looks great but I have the right rear wheel bearing out again. I JUST REPLACE THIS 2 months agao. What is up?? It should not happen at all on a62K miles car. The first one when I had tires roated we noticed it had a lot of play so It was apin in the butt and took a lot of $$ and time to push it out. THe SOB was in there tight and they thought the aluminum would bust the way they had to push but yes it was finished and it worked. Well after I swaped rims my friend says look at this and the play is all back. Another wheel bearing out in the same place??!!$% Why is somethign amiss? outl of align or bad? It shoud not happen. Please provide suggestiosn why this ouwl be failing. I can;t aford to replace these $$ things and the labor and have to do it again. Shoud I replace the arm and the whole thing from another car or any ideas? thanks
Regg
PerformanceWhite 97 Tbird LX loaded
67,000 miles
4.6 v8 with motor and exhaust upgrade
Custom Interior, Exterior and Audio
wanna be racer
1972 Cutlas Supreme 55,000 miles HO 5HIT (liscence plate)
1979 Cutlas Supreme T-top Hurst/Olds Clone, 461 Olds
Hot wheels
reckmann is offline
post #2 of 3 (permalink) Old 04-29-2004, 09:22 PM
Dan
Banned
And you replaced the races for the bearings as well ?? I have seen them go bad from overgreasing them also. If it keeps going bad, its probably something else putting extra stress on the bearings.
- Dan
Dan is offline
post #3 of 3 (permalink) Old 04-29-2004, 11:12 PM
Kevin's Avatar
Send a message via AIM to Kevin
Did you replace, or reuse that 35mm nut that holds everything together?
I learned the hard way too, took 2 bearing failures on each side before we used loc-tite to keep that nut from backing off.
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
