Will not lower?! (mark viii) - TCCoA Forums
post #1 of 4 (permalink) Old 05-22-2004, 11:10 PM Thread Starter
Kolenich's Avatar
I had new tires put on yesterday morning on my 94 and the air suspension worked fine. This afternoon I got out and it didnt lower like it always does. I have driven it a couple time and only got a message once. I have checked the rear sensor and it is still connected. It makes the clicking and sometime jerks a little like it wants to lower but doesnt. This sounds like a fairly simple problem but my service manual just tells me to run test function 211?
Any help would be appreciated.
Thank you
karl
Kolenich is offline
post #2 of 4 (permalink) Old 05-23-2004, 12:41 AM
Full Metal
RedThunder94's Avatar
you did disable the system before they jacked it up on the lift, right.....
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #3 of 4 (permalink) Old 05-23-2004, 06:46 AM Thread Starter
Kolenich's Avatar
Yes, the system worked fine friday and saturday morning.
Karl
Kolenich is offline
post #4 of 4 (permalink) Old 05-23-2004, 02:07 PM
Full Metal
that is strange, most of the people i know that had probs with the ride control was the opposite, it wouldn't raise up, did you change tire size or anything? also i think there is a relief valve that might be stuck closed, it has been so long since i worked on one of those it isn't funny.
the last car i did with an arc problem was a continental, that was back when i was still at tstc, about 8-9 years ago, so memory is alittle fuzzy, try resetting it, if that don't work, you may need a new arc controller, that what we ended up having to do with the continental, but like i tell you, the thing was slammed in the weeds, so it may be something else.
sorry man, i wish i could be more help......later'z........
