Control Arm - TCCoA Forums
post #1 of 19 (permalink) Old 05-27-2004, 01:45 AM Thread Starter
Control Arm
I went to the shop today and got a suspension check, and they told me that i needed an control arm. I was wondering did anyone have a picture of an control arm and maybe tell me the signs of knowing when i need to replace it because I delt with a lot of shops with my other cars and this time I DONT want to get GOT lol!
94cougar4.6 is offline
post #2 of 19 (permalink) Old 05-27-2004, 03:02 AM
Which control arm? Upper? Lower?
I'd guess that they saw one of your balljoint boots was shot, the upper balljoints are not replacable, you have to do the whole arm.
http://forums.tccoa.com/showthread.p...threadid=28324
Check out that thread for info about the uppers.
Chlorine is offline
post #3 of 19 (permalink) Old 05-27-2004, 06:01 AM
JustinH's Avatar
If any of the boots are ripped, then replace the arm. If there is play in any of the joints, then replace the arm.
Its really a job that just about anybody can do in their driveway. I took it to my buddies shop he replaced the two lower control arms in 20 minutes. A lift sure makes it easier though.
Get the alignment checked after for sure.
JustinH is offline
post #4 of 19 (permalink) Old 05-27-2004, 06:45 AM Thread Starter
Really I was not sure which one upper or lower i will check with them today. Does anyone have and pics of the upper and lower control arm?
post #5 of 19 (permalink) Old 05-27-2004, 07:09 AM
Rolling-Thunder's Avatar
Pictures of an upper and lower control arm?
Just turn your wheels all the way in one direction, and look at the spindle assembly. The upper control arm is a wishbone shaped piece that attaches to the upper arm of the spindle. The lower control arm attaches to the bottom of the spindle assembly, and your lower shock bolt goes thru the lower control arm also.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #6 of 19 (permalink) Old 05-27-2004, 08:55 AM Thread Starter
Ok I know what it is now so when replacing the upper to i need any kind of balljoints or anything
post #7 of 19 (permalink) Old 05-27-2004, 09:07 AM
The upper control arm comes with a ball joint already installed.
If you are going to swap it yourself, you should buy an 18mm Craftsman ratcheting wrench, with the angled ends. This will make it very eay to remove the bolt on the firewall side of the shock tower.
post #8 of 19 (permalink) Old 05-27-2004, 10:31 AM Thread Starter
for the two bolts that are by the strut what size socket is that?
post #9 of 19 (permalink) Old 05-27-2004, 10:32 AM
18 mm
post #10 of 19 (permalink) Old 05-27-2004, 10:54 AM
Overkill Fetish Freak
Those would be Lower control arms (Moog PN: K80053 LH & K80055 RH)
Dr. FrankenCougie is offline
post #11 of 19 (permalink) Old 05-27-2004, 12:20 PM Thread Starter
Ok guys i just put the upper on and the car is still making the same noise when i hit a bump what could it be?????????
post #12 of 19 (permalink) Old 05-27-2004, 12:28 PM
Sounds like the Shop you went to gave you an incorrect diagnosis.
I mentioned to you what to do via a PM.
Before you replace anything further, follow my two suggestions in the PM.
One area to check would be the tension arm, where it passes thru the lower control arm.
Here's what my PM suggested;
I would suggest you do one of two things;
1. Remove the wheel from that side of the car, and rest the frame on a jack stand.
Take a pry bar, and try to exert force on the various suspension components, as if you were trying to force the ball out of the socket (for example). You should be able to detect movement IF that joint is worn.
2. Take the car to a different shop and get a second opinion. If the two opinions match, then your all set.
Let me know how you make out.
post #13 of 19 (permalink) Old 05-27-2004, 12:30 PM
There's a picture of the Tension Arm (strut rod) bushings in this post;
http://forums.tccoa.com/showthread.p...threadid=41600
post #14 of 19 (permalink) Old 05-27-2004, 12:41 PM
Upper I believe
3ATM3 is offline
post #15 of 19 (permalink) Old 05-27-2004, 02:12 PM Thread Starter
Thanks rollingthunder. See I just got Got again. The dam car didnt even need the upper control arm. I took it to another shop just a minute ago like you said and another opinion. The reason its making that noise is because I need a strut mount on one side, they said i mite as well get the strut also. Plus i need the tension arm bushing for both side like you said but i dont need them majorly. The money i just spent on that control with tools i could of bought the strut and the mount for about the same price. Thanks alot. Maybe you should be my mechanic lol!!!!!
post #16 of 19 (permalink) Old 05-27-2004, 02:17 PM
Did you check the tension arm bushings yourself. You can check those by hand.
As far as the strut mount, did they show you what was wrong with it?
Hope this Shop is a place that you know you can trust............
post #17 of 19 (permalink) Old 05-27-2004, 03:52 PM
Well 94cougar, if the boots on your control arms looked like the picture above, it wasn't money wasted. They were due anyway.
pileit1 is offline
post #18 of 19 (permalink) Old 05-27-2004, 06:29 PM
OH thanks guys rag on the poor TBIRD owner!
3ATM3 is offline
post #19 of 19 (permalink) Old 05-27-2004, 07:18 PM Thread Starter
Cant trust none of the shops i see but yea i seen what i needed this time. AND THANKS U OTHER GUYS Yall helped ALOT also with your posts and pics. I really do appreciate it.
I bought the strut today and i see that it might not be hard to do i pretty much know how to do that. I have to put a new mount on that to.
