front strut rod front nut - TCCoA Forums
post #1 of 7 (permalink) Old 05-28-2004, 07:05 AM Thread Starter
I cannot get this nut off....its the one on the subframe. any suggestions or advice would be helpful
jnobles is offline
post #2 of 7 (permalink) Old 05-28-2004, 07:11 AM
Rolling-Thunder's Avatar
I took mine to a local Midas Muffler shop, and paid the guy $20 to loosen them.
If you can get the car in the air high enough, a 3ft. lg breaker bar on a 1/2" drive 30mm socket bit will do the trick.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #3 of 7 (permalink) Old 05-28-2004, 07:52 AM
4 Cam Bird's Avatar
I used a crescent with a pipe on the flat and a breaker bar with a pipe on the nut and it took two people.
2011 CTS-V Wagon
4 Cam Bird is offline
post #4 of 7 (permalink) Old 05-28-2004, 08:53 AM
jk69cat's Avatar
FIRE WRENCH! actually thats what i had to do on the s/c i built for my uncle .i had to heat them up with the oxy , came right off.
mn12 less!
jk69cat is offline
post #5 of 7 (permalink) Old 05-28-2004, 12:48 PM
Kevin's Avatar
Send a message via AIM to Kevin
The nut is the easy part, wait till you try and get the bolt out.
What you could do, is go to a shop and have them loosen the nut, remove the bolt, clean up the bolt, and have them put everything back together. Repeat for the other side.
It took an air-hammer/chisel to get those bolts out of my car when we did the springs this spring.
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #6 of 7 (permalink) Old 05-28-2004, 01:31 PM
jk69cat's Avatar
kevin we sell lots of lca's for just such reason!
mn12 less!
jk69cat is offline
post #7 of 7 (permalink) Old 05-28-2004, 02:54 PM
I just used a 30mm wrench, and a lot of muscle. Well, I had to cheat and use my feet to get them to break loose
Rich95XR7 is offline
