Front Shock Removal? - TCCoA Forums
post #1 of 13 (permalink) Old 05-28-2004, 02:51 PM Thread Starter
miller1995's Avatar
How do I get the front shocks out once they are free from the car? There is just barely not enough room to sqeeze them out and my Haynes manual has been no help.
-Bryan Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #2 of 13 (permalink) Old 05-28-2004, 04:06 PM
Dutch 4.6's Avatar
Dutch 4.6 is offline
post #3 of 13 (permalink) Old 05-28-2004, 05:40 PM
That's not what he was asking. Disconnect the upper balljoint and swaybar endlink, and you should have plenty of room to take it out.
Rich95XR7 is offline
post #4 of 13 (permalink) Old 05-28-2004, 05:55 PM
Dutch 4.6's Avatar
You're right. I slowly disappear to the background...
post #5 of 13 (permalink) Old 05-28-2004, 09:03 PM
Kevin's Avatar
Send a message via AIM to Kevin
I think the link is applicable - you're asking about how to change the shock once the shock+spring assembly is already out of the car right?
This may help you out: http://www.mn12performance.com/mn12h...ng_springs.htm
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #6 of 13 (permalink) Old 05-28-2004, 09:57 PM
So why would there be a space problem once they are out of the car?????
post #7 of 13 (permalink) Old 05-29-2004, 12:32 AM Thread Starter
miller1995's Avatar
Yes io am having problems gettign them out of the car. Upper ball joint studs seem reluctant to come out of the knuckle as does the end link. Which sidde of the endlink should I undo? Upper is easiest and I have already tried on one side but it was pretty hell bent on staying in the knuckle. Maybe I should just use a BFH?
Thanks for the help guys,
-Miller
SOLD1998 Escort ZX2
post #8 of 13 (permalink) Old 05-29-2004, 01:12 AM
Did you leave the bolt in the top of the spindle? I had a horrible time getting that upper ball joint out untill I drove the bolt out of there. Turns out there is a notch in the ball joint stud and the bolt goes into the notch. So the ball joint will not move untill you get that bolt out. I had to use propane and a BFH.
Chlorine is offline
post #9 of 13 (permalink) Old 05-29-2004, 10:14 AM
The first time I took mine apart, both of those gave me hell. I found that taking a small prybar, and sticking it in the slot in the spindle where the upper balljoint bolts in, and tapping it in slightly will help it release. I also took the swaybar endlinks off of the spindle, and just like you said, used a BFH, not really, I used a deadblow hammer, soft enough not to damage the bolts, but packs a punch.
post #10 of 13 (permalink) Old 05-29-2004, 12:08 PM
Kevin's Avatar
Oh yeah, that makes sense. Trying to figure out what people are asking sometimes can be tough.
Yeah take out the bolt for the upper ball joint, and then spread the clamp with a chisel or big flat screwdriver.
Having only the top of the endlink off will allow the spindle to drop far enough to let you get the strut out.
Might take alot of pounding with a BFG, just be careful not to bounce the hammer off into the fender.
Kevin is offline
post #11 of 13 (permalink) Old 05-29-2004, 01:34 PM
The best way I've found to get the upper balljoint detached is to take the nut off, pound a small crescent wrench into the gap on the front of the spindle, put a jack under the lower control arm and lift the whole assembly a bit to take the pressure off, then use a BFH and a prybar to work the bolt out. I just did this yesterday on my 89; I'm in the process of totally replacing the front suspension. Pics and a thread soon.
After disconnecting the upper ball joing, lower the jack and the assembly will drop enough for you muscle the strut assembly out. PM or email me if you've got any questions; like I said, I'm doing the same thing right now.
pdekraker is offline
post #12 of 13 (permalink) Old 05-29-2004, 09:29 PM
How bout this:
Leave the ball joint and the endlink alone. I simply freed the shock mount bolts, and used a big fukking prybar to push the lower arm low enough to slide the assemply right out. a bit of persuasion will do it.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #13 of 13 (permalink) Old 05-30-2004, 05:50 PM Thread Starter
miller1995's Avatar
Figured it out guys. They came out real easy when I took the clliper and braket off and turned the wheel.
-Miller
SOLD1998 Escort ZX2
