What do you guy's use to fix a..........???? - TCCoA Forums
post #1 of 6 (permalink) Old 06-02-2004, 05:48 PM Thread Starter
hi guy's
ok my problem is with ADDCo front sway bar 1 3/8 the bar came with red polyurethene bushings
and they make the squeaking noise every time the car bounces
is there any good lube to stop that squeaking sound it's driving me crazy
Thank's
Derek.N
Derek.N is offline
post #2 of 6 (permalink) Old 06-02-2004, 06:09 PM
4 Cam Bird's Avatar
Ford sells a bushing lubricant, I used that on my sway bars because the stuff that came with them was garbage. It really has to be driving you nuts for you to tear everything back apart to lube the bushings though. That is a lot of work for a sqeak.
2011 CTS-V Wagon
4 Cam Bird is offline
post #3 of 6 (permalink) Old 06-02-2004, 08:23 PM
Kevin's Avatar
Send a message via AIM to Kevin
Or you could just get a set of Energy brand bushings, the kind that has a grease nipple on it. Worked well on my Marquis, every time I did an oil change I greased up those bushings as well.
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #4 of 6 (permalink) Old 06-02-2004, 09:54 PM
4 Cam Bird's Avatar
I considered drilling into the bushing myself and adding a grease zert but don't know if that would actually work, and I was actually thinking of it more for the control arms than sway bar.
2011 CTS-V Wagon
post #5 of 6 (permalink) Old 06-04-2004, 04:03 PM Thread Starter
Yes Yes Yes it make's me go NUT'S
when i go over bump's every body is looking araund cuz they here my damnn sqeak
plus my car is lowerd
Derek.N
Derek.N is offline
post #6 of 6 (permalink) Old 06-04-2004, 05:02 PM
Refrigerator Raider Hater
GreenBird's Avatar
white lithium grease is a short term fix.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
