speaking of bilstein front shocks - TCCoA Forums
post #1 of 22 (permalink) Old 06-07-2004, 01:48 PM Thread Starter
Chapter Director Coordinator
jamesD's Avatar
when i was doing the UCA the other nite, i noticed the lower "perch" if you will on the front shocks for the front springs.
i see the spring rests on this perch and the top part is held secure by the rubber shock mounts, which i know bolts onto the shock itself
well.. my front bilsteins don't have those little perches, so do i have to use the OE perches or what???
someone let me know please, i was going to go have the new combo pressed together, but i don't have the perches so don't know what to do...
lemme know guys
JD
jamesD is offline
post #2 of 22 (permalink) Old 06-07-2004, 04:13 PM
U have to use the stock assembly and you i believe have to cut out the stock shock relieve the pressure remove the stock shock and insert the Koni into it correct me any one if i'm wrong
MattsLE97 is offline
post #3 of 22 (permalink) Old 06-07-2004, 05:54 PM Thread Starter
jamesD's Avatar
umm...not installing the Koni inserts.. i want to install my new front Bilstein shocks...
jamesD is offline
post #4 of 22 (permalink) Old 06-07-2004, 07:46 PM
James,
Mine came with the perches that you mentioned, they were in a bag with the 3 other parts, a nut, a rubber donut bushing and a small round metal plate. The perch is seperate and slides down the shock to a stop line embossed on the shock.
post #5 of 22 (permalink) Old 06-07-2004, 10:19 PM Thread Starter
jamesD's Avatar
hehehehe i'm a loser... . what are those other two things i pointed out?? the rubber piece was IN the perch.. but obviously, it don't go there...
lemme know
jamesD is offline
post #6 of 22 (permalink) Old 06-07-2004, 10:59 PM
The Great Obucina's Avatar
When JDs number shows up on my missed calls list, I know the shizznit hit the fan. I believe that donut is supposed to take the place of big *** foam one you already have. I think JL mentioned when Cylum busted his Bilstein on the outstanding Hillsborough county highways that it is best to reuse the factory honkin foam bushing and washer/dust cover boot thingy. Are my technical terms such as honkin, thingy, and donut making sense? I believe they are supposed to go in place of the exsting ones.....
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #7 of 22 (permalink) Old 06-08-2004, 01:05 AM Thread Starter
jamesD's Avatar
lmao JOE.. heheheh that was for my question of HOW THE F*** DID YOU GUYS GET THAT DAMN PASSENGER SIDE NUT OFF W? THE ACCUMULATOR IN THE WAY??
in caps... and of course.. the stupid ratcheting wrench don't fit... hell.. it took me less time to take that stupid power steering bolt out w/ a 10mm wrench..
jamesD is offline
post #8 of 22 (permalink) Old 06-08-2004, 05:04 AM
Joe,
Thanks for straightening that out for me also! The ones I got with mine are actually different, the rubber and the round metal piece. Good thing I don't need them.
post #9 of 22 (permalink) Old 06-08-2004, 07:16 PM Thread Starter
jamesD's Avatar
Joe..
did your dog die or something??
jamesD is offline
post #10 of 22 (permalink) Old 06-08-2004, 10:57 PM
yeah. she caught a fungal intenstinal disease. It is/was gradual, progressive and terminal..So, i couldnt let her suffer anymore, she had to go bye bye......
joseph
post #11 of 22 (permalink) Old 06-08-2004, 11:03 PM Thread Starter
jamesD's Avatar
shyt.. sorry man..
jamesD is offline
post #12 of 22 (permalink) Old 06-08-2004, 11:52 PM
4 Cam Bird's Avatar
I remember not having any idea where all the stuff that came with the shocks belonged until after I got the old shocks off the car and taken apart. And now over a year later, I don't have any recollection of what I did with the stuff that came with the shocks.
2011 CTS-V Wagon
4 Cam Bird is offline
post #13 of 22 (permalink) Old 06-08-2004, 11:57 PM Thread Starter
jamesD's Avatar
hey thanks for the LACK OF USEFUL INFORMATION YOU BUM hehehehe j/k
i figure i'll take everything to a local shop and have them compressed together.. looks pretty easy to install.. one bolt on bottom.. 3 nuts on top.. thats it.. then back to the alignment shop.. joy hehehhe
and after the UCA's not wanting to come out.. hell.. that lower bolt will be a cakewalk.. if not.. hacksaw baby....
jamesD is offline
post #14 of 22 (permalink) Old 06-09-2004, 12:11 AM
4 Cam Bird's Avatar
I did use the nut they provided and I did re use the stock dust cover
How is that for useful information?
2011 CTS-V Wagon
post #15 of 22 (permalink) Old 06-09-2004, 12:46 AM Thread Starter
jamesD's Avatar
hahaha lmao
too bad.. i want to paint the dust cover BLUE first.. oh well..
jamesD is offline
post #16 of 22 (permalink) Old 06-09-2004, 08:23 AM
4 Cam Bird's Avatar
I thought about it, but it had a good bumble bee look going with the black plastic dust cover and the eibach spring.
2011 CTS-V Wagon
post #17 of 22 (permalink) Old 06-24-2004, 08:30 PM Thread Starter
jamesD's Avatar
TTT
ok, doing front shocks/springs tomorrow..
i am "hopefully" ordering a rear addco bar tomorrow since my rear links are GONE
the book says to remove the sway bar when changing springs, so i figure now is as good a time as any
it is safe to run bilsteins and a 1" drop on front w/ sport shocks/springs on back for like a week right??
jamesD is offline
post #18 of 22 (permalink) Old 06-24-2004, 09:08 PM
you dont have to remove the rear sway bar when changing the back springs you can just disconnect the rear end links
post #19 of 22 (permalink) Old 06-24-2004, 09:09 PM Thread Starter
jamesD's Avatar
what links??
don't matter.. just an excuse to the girl as to why it needs to be changed
but if it don't need to be removed.. then i'll just try to do the rear as well and do the bar later on
but, CAN the FRONT only be done and wait a WEEK to do the REAR?
jamesD is offline
post #20 of 22 (permalink) Old 06-24-2004, 10:29 PM
Whining Intakes Rock
Al_Florida's Avatar
Originally posted by jamesD
what links??
I think you have to replace the rear pumpkin and driveshaft when you do that.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #21 of 22 (permalink) Old 06-25-2004, 01:03 AM
Fry Rice Specialist
Casper's Avatar
the engine need to be supacharged too in order for the car to run!!!
CarDomain Page
Casper is offline
post #22 of 22 (permalink) Old 06-25-2004, 09:36 AM Thread Starter
jamesD's Avatar
hey, she not that dumb... and my denny's driveshaft is sitting in its box!!
jamesD is offline
