Ball Joint Replaced, Still Clunking - TCCoA Forums
post #1 of 10 (permalink) Old 06-13-2004, 06:56 PM Thread Starter
Well, I finally replaced my upper ball joint/control arm on the passenger side yesterday and I was kinda' shocked when I took it for a test run and still heard the same annoying clunking noise from the front right side. What else could this be? Maybe shocks going bad? The lower ball joints still look good and the driver's side ball joints all look decent as well. This clunking is annoying the hell outta' me. Help? Thanks guys!
95lxv8 is offline
post #2 of 10 (permalink) Old 06-13-2004, 07:02 PM
FordFanatic's Avatar
are you sure the ball joints are good? how about the tie rods?
FordFanatic is offline
post #3 of 10 (permalink) Old 06-13-2004, 07:05 PM Thread Starter
Well, I guess someone couldn't be positive that they're good, but I didn't see any cracks in the boots on the other ball joints... Tie rods I didn't even think to look at. I'll have to check that out.
95lxv8 is offline
post #4 of 10 (permalink) Old 06-13-2004, 07:20 PM
well just because there are no cracks in the boots doesnt mean the ball joints arent bad. i think the way my father used to check them is to jack the car up and then use a nice big pry bar (he has a 6' one in his garage) and lift up on the bottom of the tire with it. there should be no play in the joint. i dont know how old your suspension components are but it probably wouldnt hurt to replace them just to be on the safe side (check some of the other posts about the ball joint falling out while driving), i dont know where everyone has been getting them but you can get the entire lower control arm for like $50. its a good investment in your safety.
edit: one more quick thing, its always a good idea to replace something like suspension parts in pairs, you replaced one side you really should replace the other.
post #5 of 10 (permalink) Old 06-13-2004, 08:33 PM
Refrigerator Raider Hater
GreenBird's Avatar
worn sway bar endlink and/or their bushings causes a clunking.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 10 (permalink) Old 06-18-2004, 01:38 PM
TMcColl's Avatar
Send a message via AIM to TMcColl
I had a clunking noise on the drivers side and after replacing everything (it needed it anyway) the clunk was still there. It turned out to be the sagging door.
Tony
Tony McColl
1994 LX 4.6L
New motor as of Aug 1st.
No Dyno Numbers yet.
Just two runs at 5800 ft.
http://www.cardomain.com/ride/2203515
TMcColl is offline
post #7 of 10 (permalink) Old 06-18-2004, 02:40 PM
I had a similiar problem, after replacing the LCA's I noticed that the shock bushing on them was hosed bad. Haven't heard a sound since getting them replaced. I assume that the clunking was the shock wobbling around in the LCA mount.
Dave
rocket_dj is offline
post #8 of 10 (permalink) Old 06-21-2004, 11:07 PM
Send a message via AIM to gopedxr7
i have a annoying clunking sound. i am totally confused what the heck it is. i just finished replacing the upper ball joints today and i still hear it. its driving me crazy. it sounds like its comming from under the motor or something. i hear it when i rock the car side to side in park too.
alan
1986 Mercury Cougar GS (RIP Dec 1985-Nov 2002)
1993 Ford Thunderbird LX (Jan 2004 - Feb 2005 sold but might be returning to be parted out)
2004 Chevy Monte Carlo LS (the tbird replacement)
I need another thunderbird or cougar....
gopedxr7 is offline
post #9 of 10 (permalink) Old 06-22-2004, 12:40 AM
Full Metal
RedThunder94's Avatar
alan
i agree with greenbird, it is more than likely the swaybar endlinks.
ps, i also replied to your thread "about to go nuts," . later'z.....
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #10 of 10 (permalink) Old 06-22-2004, 06:47 AM Thread Starter
Dave
This seems like it'd be the closest answer to my question. I'm going to have to check that out when it quits being crappy out around here.
95lxv8 is offline
