AutoZone Rack and Pinion Experience - TCCoA Forums
View Poll Results: Do You Recommend the Use of AutoZone R&P?
I recommend them!! (I have used them and had no problems with 50K + miles) 0 0%
I don’t recommend them!! (I have used them and they started leaking soon after installation) 1 100.00%
Voters: 1. You may not vote on this poll
post #1 of 7 (permalink) Old 06-23-2004, 09:00 AM Thread Starter
I have a new AutoZone (remanufactured) R&P to install along with my suspension upgrade. However, I've recently been reading horror stories about then starting to leak, etc.
So my question is: Who has used them and what has been your experience.
My current R&P isn't having any problems what so ever, but it also has 268K miles on it.
Thoughts or suggestions.
69 F100 LWB w/460 Engine
post #2 of 7 (permalink) Old 06-23-2004, 11:00 AM
Jedi Master
mn12xr7's Avatar
I'm interested in this too! I'm gonna be doing mine this weekend if not the following...
-Orlando
mn12xr7 is offline
post #3 of 7 (permalink) Old 06-23-2004, 12:20 PM
I installed one about 4 years ago, no leaks yet. But they came with the wrong
inner tie-rods. There was not enought adjustmen threads on them. Compare them with your stock ones and see how much thread is on the tie rod. I ended up getting swapping with some TRW tie rods, I already had installed on my old rack. .
cougarsc is offline
post #4 of 7 (permalink) Old 06-23-2004, 01:51 PM
jk69cat's Avatar
what kinda dollars?
mn12 less!
jk69cat is offline
post #5 of 7 (permalink) Old 06-23-2004, 05:30 PM
I had a reman'ed rack and pinion that lasted a year before it started leaking all over and clunking. I rebuilt my whole front suspension and still had a clunk up until today when i replaced that sucker. Put in a reman'ed Ford/Motorcraft unit and MAN what a difference! The old one was very very hard to steer, clunked when i hit the brakes, leaked, and was poorly reman'ed. The new one is the opposite. Quiet as anythin, i can steer it w/ my pinky, and no leaks or clunking noises. It's great....
You might not have a problem w/ the one you get, but just be sure you take a look at it when you go to buy it and make sure it meets your needs as far as how well you think it was built. The ford unit was $205 btw.
94birdnj is offline
post #6 of 7 (permalink) Old 06-24-2004, 08:24 AM
jk69cat's Avatar
i was wondering bout the az unit, yes i know the ford rack is 205 pn f6sz3504acrm , i put a used rack in mine , 50 bucks, came out of a car that only had 60,000 .
mn12 less!
jk69cat is offline
post #7 of 7 (permalink) Old 06-26-2004, 06:14 AM
AZ unit is ~$95 w/ a $85 core i believe....
94birdnj is offline
