Getting ready to do my suspension... - TCCoA Forums
post #1 of 3 (permalink) Old 07-03-2004, 11:53 PM Thread Starter
I'm going to be doing my suspension in a week or two, I wanted to see what everyone thinks of my setup... I've got the Vogtland (GP) springs on Sport fronts and Cobra rears along with the ADDCO big bar set, and I'm going to be fabbing up some STB's to toss in there too. I'm also picking up some 18's with 245's on em from another TCCOAer here. I think that should really wake up the handling on this Bird.
SloMo228 is offline
post #2 of 3 (permalink) Old 07-04-2004, 08:49 PM
Do it right and don't forget new spring isolators and front strut mounts at a minimum. And while you're under there, check all the bushings and balljoints to make sure they are good, you have to drop the front subframe to replace the swaybar, and if you're going that far, you may as well replace anything else that needs it.
Rich95XR7 is offline
post #3 of 3 (permalink) Old 07-17-2004, 03:16 AM
Send a message via Yahoo to BIG PERV
Make sure you line the engine cradle back up right. or you won't be able to align it, I had to redo mine because the cradle was a bit off after it got done, had to pay for 2 alignments.
BIG PERV is offline
