big trouble - TCCoA Forums
post #1 of 4 (permalink) Old 07-04-2004, 09:54 AM Thread Starter
SilverLx's Avatar
Send a message via AIM to SilverLx
big trouble
While changing my front break pads, i take a look inside the wheel well and notice everything needs changed out. And I mean everything. From the upper control arm to almost everything that i don't know the name of. The rubber "stuff" (no idea what it's called) is gone on both sides. I thought the squeak was from the break pads..but i guess not.
I really need basically everything, i just don't know where to look. Any help or information would be appreciated.
SilverLx is offline
post #2 of 4 (permalink) Old 07-04-2004, 10:57 AM
Whining Intakes Rock
Al_Florida's Avatar
Bushings.
You can get most of what you are looking for at http://www.rockauto.com They have pretty cheap prices. I've ordered from them before. As for the parts they don't have, if cash wasn't too much of a problem, you can get polyurethane bushings from http://www.mn12performance.com
The upper and lower control arms you get from Rock Auto have the ball joint and the bushings already installed but they are the stock rubber bushings.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 4 (permalink) Old 07-04-2004, 11:09 AM
Hey SilverLX.
I've had the same problem, but not as bad. It was mostly a crunch noise, and bad steering. My car started to pull bad to the left.
MN12 Performance sell a bushing kit
Also you can build your own kit like I did, with Moog parts. Here is the Moog website http://www.federalmogul.com/cda/chan...2_7110,00.html This site is funky in how it works, but if you keep tring it will give you the part # for all bushing and suspension parts you'll need. These part # are the same CarQuest uses.
I paid $380, for all items.
Big note. I put the Sturt rod to frame bushing on backwards, Which caused it to brake down in a few months. I know now that the bigger bushing goes in the front.
Jhrea is offline
post #4 of 4 (permalink) Old 07-05-2004, 01:43 AM Thread Starter
SilverLx's Avatar
Thanks, appreciate it guys.
SilverLx is offline
