"Wheel bearings" - TCCoA Forums
post #1 of 20 (permalink) Old 07-09-2004, 03:58 PM Thread Starter
SilverLx's Avatar
Send a message via AIM to SilverLx
"Wheel bearings"
I've had an odd squeak from the front of my car when I am doing anything but breaking. It is obviously comming from the wheelwell, and I was told by someone that it could be my "wheel bearings". I've never heard of wheel bearings, and am wondering how much and how hard they are change.
I know it's not my brake pads, i just changed those last week, and the squeak was thre before and after the change. It is just getting worse now. Any suggestions would be appreciated.
SilverLx is offline
post #2 of 20 (permalink) Old 07-09-2004, 04:21 PM
Whining Intakes Rock
Al_Florida's Avatar
The wheel bearings on the front are not replaceable. You have to buy the hub assembly which includes the bearings. http://www.Rockauto.com is currently selling the hub assembly for $65 each. Also do a search for "rock auto discount" here on the forums. it's a number you can put in to get another 5% off.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 20 (permalink) Old 07-09-2004, 05:00 PM
Lazania's Avatar
It might be just one side but I would change both so they both usually go at the same time, turn your wheel left and right if it goes away when your turn right then its the left side and vise versa.
2011 Mustang GT Premium 6spd
Current Modifications:
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #4 of 20 (permalink) Old 07-09-2004, 05:04 PM
I haven't heard of them squeaking. They tend to hum or whine, usually when straight or turning one way or another.
How's the A-arm bushings? It's a common repair on these. Does it squeak on bumps?
soop is offline
post #5 of 20 (permalink) Old 07-09-2004, 06:46 PM Thread Starter
SilverLx's Avatar
It is more of a whine i guess, but yeah, all the bushings are shot i know, but i don't think that's where the sound is comming from. As for when the sound comes, man it comes anytime everywhere, any which way i turn the wheel, except braking.
SilverLx is offline
post #6 of 20 (permalink) Old 07-09-2004, 07:55 PM
Sweet T
SanDiegoLXBird's Avatar
So what is the squeeking then? It happens in circumstances like SilverLX described, usually below 20-25 mph. I was thinking it was hub bearings for the longest time...
SanDiegoLXBird is offline
post #7 of 20 (permalink) Old 07-09-2004, 08:15 PM
Lazania's Avatar
Struts??
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #8 of 20 (permalink) Old 07-09-2004, 08:16 PM
Sweet T
ONly happens when the car is in motion. I've got squeeking from the shocks and suspension.. but this squeek is only when the car is rolling.
post #9 of 20 (permalink) Old 07-09-2004, 08:19 PM
rocket_dj is offline
post #10 of 20 (permalink) Old 07-09-2004, 08:24 PM
Lazania's Avatar
Def possibility, how are your brakes??? could be a caliper sticking too
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #11 of 20 (permalink) Old 07-09-2004, 11:10 PM
Originally posted by rocket_dj
Could be something like this..http://forums.tccoa.com/showthread.p...threadid=43337
That's very extreme. Shouldn't normally get that far gone.
soop is offline
post #12 of 20 (permalink) Old 07-10-2004, 09:34 AM
JustinH's Avatar
moving..
JustinH is offline
post #13 of 20 (permalink) Old 07-10-2004, 11:44 PM Thread Starter
SilverLx's Avatar
How hard is it to change the hub?
SilverLx is offline
post #14 of 20 (permalink) Old 07-11-2004, 11:09 AM
Al_Florida's Avatar
Not difficult at all.
Remove the brake caliper and hang it out of the way. No need to disconnect the brake line.
Remove the rotor and take off the grease seal and get a new one.
Remove the hub retainer nut and get a new one. New seal and bolt are a few bucks. Cheap insurance.
Hub should come off at that point. Might need a little BFH persuasion.
Putting it back on you have to make sure you have a big enough torque wrench. It's torqued to 225-254 ft lbs.
# 0 rows returned
post #15 of 20 (permalink) Old 07-11-2004, 08:58 PM
Rolling-Thunder's Avatar
Hub retainer bolt?
Don't you mean nut? The 36mm one?
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #16 of 20 (permalink) Old 07-12-2004, 12:29 AM
Al_Florida's Avatar
Originally posted by Rolling-Thunder
Hub retainer bolt?
I meant the nut, thanks for catching that.
# 0 rows returned
post #17 of 20 (permalink) Old 07-14-2004, 02:10 AM
The Band, not the Disease!
AnthraxBird's Avatar
Same think on mine, it will go "squeek, squeek, squeek" when you go faster the squeek gets faster, etc. When you apply breaks, it goes away. I was thinking the caliper bolts.. the 2 bolts the caliper slides on? Maybe the rotors are slightly warped, and cause the caliper to travel back and forth, causing it to squeek? Did you lube the ears on the brake pads? I'm going to go in and re lube everything.. I only did the pads, which I didn't get very well. (They kept popping out, and the grease was everywhere accept the ears on the pads...)
AnthraxBird is offline
post #18 of 20 (permalink) Old 07-14-2004, 10:01 AM
gee3666's Avatar
Send a message via Yahoo to gee3666
I also have the same prob, I know the bushings r toast, but my sound is definitely an itermittent squeak. gets faster as I go faster, stops when i apply brakes, but its always there when im in motion. I'm prob gonna wind up repalcing most of my front end anyway so this info helps alot.
George
The hummingbird hums..... the Thunderbird ROARS!
gee3666 is offline
post #19 of 20 (permalink) Old 07-19-2004, 11:44 AM Thread Starter
SilverLx's Avatar
I replaced my rotors since they were warped anyways, did the trick. No more sound at all.
SilverLx is offline
post #20 of 20 (permalink) Old 07-19-2004, 12:36 PM
Some brake pads have a "sensor" tab that rubs on the rotors when the pads get thin. This causes a squeek that will go away when the brakes are applied.
This might apply to some of the situations described.
JD
JDPascal is offline
