JB Weld Rear STB? - TCCoA Forums
post #1 of 7 (permalink) Old 07-10-2004, 08:25 PM Thread Starter
Will3799's Avatar
Send a message via AIM to Will3799
JB Weld Rear STB?
Is JB Weld strong enough to weld a rear STB? It would be alot easier to make.
Will
Fear the insanely fast Thunderbird with SECRET mods!
Secret not meaning Fram filter and removed air silencer.
Yeah…definitely not
Future mods
5-Speed
Will3799 is offline
post #2 of 7 (permalink) Old 07-10-2004, 09:31 PM
I wouldn't use it. It's too easy to have someone weld a couple beads.
Rich95XR7 is offline
post #3 of 7 (permalink) Old 07-10-2004, 11:50 PM
dode's Avatar
No
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #4 of 7 (permalink) Old 07-12-2004, 06:43 PM
Tell you what: make an STB with JB Weld, then hit it with a hammer. I'll bet the glue will break. You and a hammer don't have nearly the force of a 4,000 pound Thunderbird plus the additional force generated by suspension travel. This would be an extraordinarily bad idea.
mercutio is offline
post #5 of 7 (permalink) Old 07-12-2004, 07:52 PM Thread Starter
Will3799's Avatar
Thanks everyone
Yeah…definitely not
Future mods
5-Speed
Will3799 is offline
post #6 of 7 (permalink) Old 07-13-2004, 12:25 AM
4 Cam Bird's Avatar
That would be one way to find out how much that brace really does. If it survives, it would prove that it doesn't see much force at all. If it breaks it doesn't really prove anything since it wouldn't take much force to break, but it would prove that the bar does a little something anyway. Give it a try, let us know how long it takes to break. It isn't like it will fail catastrophically. You won't even know it happened until the next time you open your trunk. Unless you can hear it rolling around back there after it comes apart. Then you can clean the JB off and take it somewhere to get welded up for real.
2011 CTS-V Wagon
4 Cam Bird is offline
post #7 of 7 (permalink) Old 07-14-2004, 02:05 AM
The Band, not the Disease!
AnthraxBird's Avatar
JB weld sucks. Don't even try to use it for anything. It's complete GARBAGE. Go to a local muffler shop and have them weld it.. they would probly do it for 10 bucks...
AnthraxBird is offline
