After days of sitting, car is "stuck" - TCCoA Forums
post #1 of 9 (permalink) Old 07-15-2004, 09:14 PM Thread Starter
Question After days of sitting, car is "stuck"
I have another question about my 96, and I tried searching first. Right now, it is sitting in my garage--it doesn't have a plate, and it's not insureed, so it doesn't move much.
So, a couple of times, I made the mistake of letting it sit for over a week. When I finally got around to starting it, it started just fine. But, when I went to pull out of the garage (my owner's manual recommends moving it at least every 15 days) the front end is locked/frozen. So, I slowly apply the gas, and the rear tires start spinning on the smooth garage floor before the car starts to move forward.
I know just enough about cars to realize this could be many different things, but what do you experts think it probably is? Do I need to worry alot about this? Will this problem go away when I start driving this car regularly?
I really feel like a moron for actually pushing the gas to get the car to move --I get a sinking feeling in my stomach, and I think something really bad is gong to happen--but it does break loose, and seems to be fine afterward.
Black_97_LX is offline
post #2 of 9 (permalink) Old 07-15-2004, 11:14 PM
that isnt normal my ar has been parked over a month and it started and drove just fine , i would check that could be your brakes getting stuck or something that if it isnt fixed could en being dangerous /serious.
turbospeed is offline
post #3 of 9 (permalink) Old 07-16-2004, 12:04 AM
Refrigerator Raider Hater
GreenBird's Avatar
I store my car in the winter, which in VT is 7 to 8 months. I've never had that problem.
I would check the front brakes, although I'm not sure why it would do such a thing.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 9 (permalink) Old 07-16-2004, 05:53 AM
That happens to some of my parts cars (which sit outside, all the time). If the brakes aren't used for a length of time, especially in a high humidity situation, the rotors rust and sometimes get stuck to the pads. After they break loose, applying the brakes a few times at low speed usually knocks the rust off the rotors.
-Rod
post #5 of 9 (permalink) Old 07-16-2004, 06:06 AM Thread Starter
Thanks for the replies everyone. I think it is what racecougar said happens to his parts cars--the rotors are definitely rusty, Because it sits in the woods, there is a lot of moisture in my garage, and the car sat outside at the dealer for a long time before I got it. But I'll definitely keep a close eye on it.
post #6 of 9 (permalink) Old 07-16-2004, 11:24 AM
My racecar does the same thing. I tried to move it a last month, and since it has no engine in it right now, it took about 5 people to move it, and it only wieghs about 1500lbs without the engine and tranny.
Rich95XR7 is offline
post #7 of 9 (permalink) Old 07-16-2004, 11:54 AM
GreenBird's Avatar
but how could the pads stick to the rotors if the pads weren't touching the rotors? I know your not supposed to set the parking brake for this very reason, but even if you did ours only engages the rear.
96 Alpine Green V8
post #8 of 9 (permalink) Old 07-16-2004, 12:06 PM
Whining Intakes Rock
Al_Florida's Avatar
Sounds like a caliper piston rebuild is in the future.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #9 of 9 (permalink) Old 07-16-2004, 10:46 PM
The pads are just about always in light contact with the rotors. This problem is particularly bad with metallic brake pads.
-Rod
