Are the the airbags reccommended? - TCCoA Forums
post #1 of 16 (permalink) Old 07-21-2004, 10:49 PM Thread Starter
For the rear suspension to avoid bottoming out or whatever?
Just curious
Dave
DMcBrideBoston is offline
post #2 of 16 (permalink) Old 07-22-2004, 07:52 AM
fast Ed's Avatar
I'd recommend them !!
When I"m going to a track event, I'll have a complete set of wheels & tires in the car, along with a trolley jack, tool box, spare brake parts, etc. The Airlift bags do a great job of keeping the fender lips off the wide tires.
cheers,
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #3 of 16 (permalink) Old 07-22-2004, 09:05 AM
392Bird's Avatar
Just make sure that they are not connected together on our cars. With IRS, if you connect them it will hurt corning. When connected, they will equalize the pressure on both sides. When car is turning left, the right side would get compressed, trying to raise its pressure. Some air would transfer to the other side, and cause even more lean.
They work great on the strip also. This allows you to load the right rear more, to help the car launch straight, and reduce wheel hop.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #4 of 16 (permalink) Old 07-22-2004, 04:36 PM
I install them in every MN12 that I put together. I definitely recommend them.
-Rod
post #5 of 16 (permalink) Old 10-06-2004, 09:38 PM Thread Starter
Alright, I think I am going to do these soon.... How hard is the install (hours/complexity) and do you need to buy anything extra besides what comes wit them?
Where is the best place to get them?
Thanks Alot
Dave
EDIT: I found some - Are these the correct ones?
Summitt Racing Part Number AIR-60776 for 68.99
So all I need to know is, do I have to buy anything else to install these or have the install perfect and easy access to the valve.
post #6 of 16 (permalink) Old 10-07-2004, 06:12 PM
The hardest part about the install is drilling a hole in each lower control arm. All in all, it's a pretty simple install.
Kit # 60789 is for 89-91, kit # 60776 is for 92-97. Summit sells them. The kit should have everything necessary to install them correctly.
-Rod
post #7 of 16 (permalink) Old 10-29-2004, 01:37 AM Thread Starter
Would this be ideal for filling the bags?
Or is there another compressor available for about the same money?
Dave
post #8 of 16 (permalink) Old 10-29-2004, 02:06 AM
That should work just fine, but for the money, why not just fill them up when necessary with a shop air compressor? As long as you don't have a leak, you shouldn't have to fill them up often at all. I have to top mine off once every two months or so.
-Rod
post #9 of 16 (permalink) Old 10-29-2004, 02:35 AM Thread Starter
You keep them at a certain height always?
Wouldn't you want to raise the car when racing, and go back to normal when not racing?
My car is slammed, so I don't want the rear up always, it will look wierd.
Dave
Rod, Please check your PM's.
post #10 of 16 (permalink) Old 10-29-2004, 03:28 AM
Chapter Director Coordinator
jamesD's Avatar
really... lowered 1 inch. how much rise we talking?
jamesD is offline
post #11 of 16 (permalink) Old 10-29-2004, 03:52 AM Thread Starter
Me or Rod?
Dave
post #12 of 16 (permalink) Old 10-29-2004, 04:23 AM
jamesD's Avatar
Rod
jamesD is offline
post #13 of 16 (permalink) Old 10-29-2004, 04:25 AM Thread Starter
Okay, but I am missing something.....
It's too damn late/early ...
post #14 of 16 (permalink) Old 10-29-2004, 04:27 AM
jamesD's Avatar
you asked about height.. i too am curious since i am dropped a bit
red sox fever still affecting you?? j/k
jamesD is offline
post #15 of 16 (permalink) Old 10-29-2004, 04:30 AM Thread Starter
Yeah...I am lowered 2.5-2.75 inches, and still getting lower.
Red Sox Fever is screwing me all up, catching it more tomorrow night, when I get my 2004 World Series Champions tattoo
post #16 of 16 (permalink) Old 10-29-2004, 09:52 AM
Dave,
Since this is my daily driver, I don't take it to the track too often. Plus, it is so easy to change the pressure in the bags. I mounted the valves in the spare tire well in the trunk, so that they are easy to access but still hidden.
My car is lowered 1" with the Vogtland springs. The difference between 5 psi in the bags (minimum recommended pressure) to 42 psi in the bags is about 1/2" in the rear. I run 42 psi in the bags simply because I wasn't happy with the "mushiness" of the rear Vogtland springs, so the air bags help firm it up.
I received your PM. It will take me a little bit to get the part numbers together for you, I have to look them all up online.
-Rod
