1\4 Sway Bar Vs 1 3\8 - TCCoA Forums
post #1 of 21 (permalink) Old 08-01-2004, 11:58 AM Thread Starter
Lazania's Avatar
ok, If I can get a killer deal on a 1 1\4 sway bar kit front and rear. how much better is the 1 3\8 kit , I dont ever plan on autocrossing.
2011 Mustang GT Premium 6spd
Current Modifications:
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #2 of 21 (permalink) Old 08-01-2004, 09:29 PM
I'm running the 1 3/8" bars with the MN12 bushings. I would not go that extreme if I was to do it again. They can be a bit jarring when turning into some driveways. Most of the time it is fine and the car drives like it is on rails.
Andrew
aoldenbu is offline
post #3 of 21 (permalink) Old 08-01-2004, 10:42 PM Thread Starter
Lazania's Avatar
How much better do you think the 1 1\4 bar is compared to the 1 3\8's??
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #4 of 21 (permalink) Old 08-02-2004, 11:54 AM
Send a message via AIM to Kleckner
IMO, the 1-3/8 is not needed. I autocross and track my car, and the 1-1/4" bars are just fine. The best set-up I have had is with a 1-1/4 ADDCO rear bar, and an '89 SC front bar, both with poly bushings.
Kleckner is offline
post #5 of 21 (permalink) Old 08-02-2004, 04:21 PM Thread Starter
Lazania's Avatar
thanks , I also has my car on the lift today and Im alsmost 100% sure you dont have to remove the K member to get the front sway bar out. Some people have been saying this.
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #6 of 21 (permalink) Old 08-02-2004, 06:37 PM
I tried it for quite a while unsuccesfully. If the engine is not in the car, you might be able to get away without dropping the cradle.
When I did it (4.6L car), the cradle had to drop, and the engine had to be raised. Of course, that winter I had the entire car torn apart, but I could not wait to do it.
Kleckner is offline
post #7 of 21 (permalink) Old 08-02-2004, 07:30 PM
Mark M. TCCoA VP's Avatar
Getting the stock bar out without removing the K-member is not the problem it is the larger bar going back in that is. I came up with the ADDCO install as really the only way to do it. Most thought it could not be done in the first place.
Mark
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #8 of 21 (permalink) Old 08-02-2004, 07:41 PM
Mark, you have the big bars, don't you? I'm currently debating on which ones to get for Autocross/Street Duty with Konis and H&R's, and a set of chassis braces.
Rich95XR7 is offline
post #9 of 21 (permalink) Old 08-02-2004, 08:32 PM
Hi Rich,
I have the 1st prototype 1 3/8" bars on my Cat and would not change them for the world. I've also have all the other suspension parts on my car and have had all the combos on my car and ended up with the big boys. IMHO get the big bars.
Mark
post #10 of 21 (permalink) Old 08-02-2004, 10:00 PM
JustinH's Avatar
mark,
care to make a roadtrip to the lovely Western New York to install the front bar in my car?
It looks like alot of fun.
Larry? Anybody?
JH
JustinH is offline
post #11 of 21 (permalink) Old 08-02-2004, 10:12 PM Thread Starter
Lazania's Avatar
Originally posted by JustinH
mark,
Larry? Anybody?
JH
Ill talk to my buddy tony , he might do mine b\c I have been so busy.
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #12 of 21 (permalink) Old 08-03-2004, 02:28 PM
Matt C's Avatar
If you go with the big bar you better get an oil filter relocation kit. Take it from me, wresting the oil filter out around the bar is a pain in the [email protected]#
1997 LX Sport..Eibachs & KYBs...245/50s on Eagle Alloy 16x7s...SC rear sway bar...94 SC seats...Mark VIII ds...SCT tuned by Lasotta Racing ...Dirty Dog Marauder converter... Trans by Supergordo
Matt C is offline
post #13 of 21 (permalink) Old 08-03-2004, 02:38 PM
4 Cam Bird's Avatar
Oh come on, be adventurous. It is fun to push your filter back to get it on top of the bar, push the lower rad hose out of the way, pull the filter forward, push the overflow hose out of the way, pull it forward some more, turn it, wiggle it, and pull it down around the front end of the strut rod, lower rad hose, sway bar, and everything else that is right there. Its a lot of fun. Its even more fun getting the new filter back in to. Don't move it, that would make things too easy.
2011 CTS-V Wagon
4 Cam Bird is offline
post #14 of 21 (permalink) Old 08-03-2004, 02:50 PM
Not a problem with the 5.0
post #15 of 21 (permalink) Old 08-05-2004, 07:16 AM
rustyul's Avatar
Yeah, it sure is fun allright....especially when there's hot oil all around and the filter is so hot you can barely touch it! Gloves make the job more difficult!
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #16 of 21 (permalink) Old 08-05-2004, 08:30 AM Thread Starter
Lazania's Avatar
you shouldnt be changing the oil on a hot engine
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #17 of 21 (permalink) Old 08-05-2004, 06:53 PM
Illinois Chapter Director
TydlwavS's Avatar
Send a message via AIM to TydlwavS
I love the big bars.
I pull my filter out the top and put my filter in from up top.
I put the large bar in with the motor out. If you have any reason to pull the motor you can easily get the big bar in with the motor out!
"That is the worst looking car in the whole world. I'd rather look at one of your dingle berries"
Check out what we've been up to....
http://forums.tccoa.com/forumdisplay.php?f=54
TydlwavS is offline
post #18 of 21 (permalink) Old 08-11-2004, 01:49 AM
mn12performance sells bushings for 1 3/8" sway bars?
68COUGAR
68COUGAR is offline
post #19 of 21 (permalink) Old 08-11-2004, 07:26 AM
lobo's Avatar
Send a message via Yahoo to lobo
I have the 1 1/4 bars front & back, with Suspension Tech springs and Bilsteins...car handles great, but I can feel every rock I run over, especially with 45 series tires.
2013 Mustang GT...2013 Escape
lobo is offline
post #20 of 21 (permalink) Old 08-11-2004, 12:03 PM
4 Cam Bird's Avatar
I'm pretty sure I can't see my oil filter from up top to get it out. I might be able to drop the new one in from up top, if I got luck y I might be able to reach it where it came to rest.
2011 CTS-V Wagon
post #21 of 21 (permalink) Old 08-11-2004, 09:50 PM
TydlwavS's Avatar
Well, I loosen it from under the car and shove it to where I can grab it from up top. Add a Vortech SC bracket to the mix...it's not fun or easy, but it does happen.
TydlwavS is offline
