ATTN: People with Lowered 'Birds - TCCoA Forums
post #1 of 6 (permalink) Old 08-01-2004, 06:05 PM Thread Starter
Hey, I'm planning on making 'er fly a little lower pretty soon and I've been searching and searching and there's still some questions that I have. I've developed an annoying rattle/clunking noise recently and I believe it's my front sway bar end links. Since I'm going to be lowering the car, should I buy shorter ones? Also, where do I get them? Someone said I could get them right off the shelf at a local parts store, like AutoZone, but the guy behind the counter said they wouldn't work and showed me a little 3-4" bar with (what looked a lot like) ball joints on either end... He said those were the aftermarket replacement end links... They looked nothing like what I needed. How much shorter do I need?
Also, I'm not sure if I want to purchase SpringTech springs or buy a set of SC springs and trim them. Any input on what I should do would be awesome.
And finally, what all am I going to need to upgrade/replace when I install the new springs? I've heard conflicting opinions about the rear sway bar endlinks, etc...
Maybe I could get in touch with someone that knows alot about the MN12 suspensions so I could just rattle my questions off and get a few answers if somebody doesn't mind.
Thanks in advance!
95lxv8 is offline
post #2 of 6 (permalink) Old 08-01-2004, 06:15 PM
Well i can answer one of your questions about upgrading the rear sway bar endlinks. If you have the stock sway bar back there you do not need to. You will get that answer from alot of people so i thought i would chime in first If you have an aftermarket one yes you will need new endlinks. As for the front same thing you can use the stock links. I have eibachs on my coug lowered 1.5 all around and they went in perfect. While your in there check upper and lower control arm ball joints any anything else that looks worn. Oh depending on how bad they are i would replace the strut rod bushings that go through the LCA. They dont need to be pressed in and they come in pairs of 2 for the front and rear of the LCA. Hope this helps you some
MattsLE97 is offline
post #3 of 6 (permalink) Old 08-02-2004, 09:37 AM
I would personally go for Eibachs, and I would definently not get some SC springs and cut them. The SC springs tend to raise our LX's even more. Have you considered shocks also??
-Brian
TbirdJLcustom is offline
post #4 of 6 (permalink) Old 08-02-2004, 03:05 PM
There's nothing wrong with cutting SC springs a little. They maintain a good ride unless you go over 3" lowered. Here's an example of how high a Cougar sits with uncut SC springs/Sport shocks.
Rich95XR7 is offline
post #5 of 6 (permalink) Old 08-02-2004, 03:32 PM
i would like to hear the answer to the solution for front end links w/stock bar on lowered car. i lowered mine yrs ago and now its time for end links.
whats the best option for the stock front bar?
thnx
1994 Thunderbird - Renegade Racing Long block, TFHS Trans, NA/SVO intake. Cam94 lives!
2010 Shelby GT500 - Black/Silver
1995 Thunderbird LX - 2000 GT PI Swap by W&S Motorsports - Sold on Tccoa.
Bill H is offline
post #6 of 6 (permalink) Old 08-08-2004, 08:41 AM
As far as the ST springs go......They dropped my car, well, basically to the ground. 2-3 inches....
Dave
DMcBrideBoston is offline
