how to install jl's rtlb? - TCCoA Forums
post #1 of 11 (permalink) Old 08-02-2004, 10:21 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
try for 3 hours using different method either the back sit at the ground or both in the air or even one wheel at the ground there's no way i can put it in. using hammer and half way through that bar will just spring out. hellllppppp~~~~
CarDomain Page
Casper is offline
post #2 of 11 (permalink) Old 08-03-2004, 12:12 AM
4 Cam Bird's Avatar
It fits real tight. Try this, get a bar that is slightly shorter than where the brace goes into. Get a nut and a bolt. Put the nut on the bolt. Put the bolt into the end of the bar. Now stick the bar bolt set up between the mounting points of the brace in such a way that you will still be able to get the brace up there. Use wrenches to back the nut off the bolt which essentially makes your bolt rod combination longer. This will help spread it apart to aid in getting the brace in. Clamping devices and BFH's are also still helpful. You'll probably need two people. Have someone hold the bar with a pipe wrench while you turn the bolt out so it doesn't slide around too much.
2011 CTS-V Wagon
4 Cam Bird is offline
post #3 of 11 (permalink) Old 08-03-2004, 05:29 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
I've had 2-3 people complain about the RTLB being a really tight fit,and then others have said that the piece simply falls out while they're trying to start the bolts.It seems that Ford has a really loose tolerance on the rear K-member.
4 cam has a good idea..I never though about trying that..
JL
Fuelly
Johnny Langton is offline
post #4 of 11 (permalink) Old 08-03-2004, 09:30 PM
4 Cam Bird's Avatar
Thats exactly what I had to do to get mine in. It worked but still did not go in easily. The clamp I was using wasn't a C clamp but a squeeze handle type clamp, not sure what they are actually called. Was also using a hammer. Good luck
2011 CTS-V Wagon
post #5 of 11 (permalink) Old 08-03-2004, 09:57 PM
Worked for me!
post #6 of 11 (permalink) Old 08-07-2004, 12:35 AM Thread Starter
Fry Rice Specialist
Casper's Avatar
was thought about the 4 cam bird's way but always fear that route will twisted the mounting point and break the weld. but if it works for you then i might as well try.
CarDomain Page
Casper is offline
post #7 of 11 (permalink) Old 08-10-2004, 10:06 AM
BirdofPrey97's Avatar
Talking
4 cam, I dont "understand" your instructions.....Can you come over to IA this weekend and "show" me what you are talking about?!?!?!?!?
JL, I need to get this from you. Let me know this shipping charge to 55318 please.
Todd
Honor, Grace, and Dignity.....Do you remember these?
BirdofPrey97 is offline
post #8 of 11 (permalink) Old 08-10-2004, 10:34 AM
4 Cam Bird's Avatar
I'll be in Sioux City next weekend most likely
2011 CTS-V Wagon
post #9 of 11 (permalink) Old 08-10-2004, 10:40 AM
j/k......thought maybe a joke would lighten me up a bit from work stress. Going to be replacing control arms and bolts this weekend. Teach me to go off roading. Should of slowed down for that corner I guess.
post #10 of 11 (permalink) Old 08-10-2004, 11:41 AM
4 Cam Bird's Avatar
I read that, work, stress, ha. Liven up the boredom maybe.
2011 CTS-V Wagon
post #11 of 11 (permalink) Old 08-10-2004, 04:05 PM
Todd
$78 shipped dude..I'm about 2 weeks max out from having more ready.
JL
Fuelly
