Polyurethane Suspension Bushing Grease - TCCoA Forums
post #1 of 5 (permalink) Old 08-10-2004, 06:07 PM Thread Starter
4 Cam Bird's Avatar
What in the world is this stuff actually. I looked all over town today and didn't find any grease the looked remotely close to what comes with the bushings. When I did then I also used some stuff from Ford which I find out now, has been discontinued (dad had the tube we used, it was an old tube). The grease used worked very well. Everything I've taken back apart was well covered still. Where do I find this stuff? What do I ask for? The closest thing in appearance I have seen, is actually the dielectric grease I have Would this be suitable for use on bushings
2011 CTS-V Wagon
4 Cam Bird is offline
post #2 of 5 (permalink) Old 08-10-2004, 07:45 PM
I just used some axles bearing grease my dad had in our garage. I think they all do the same job
MattsLE97 is offline
post #3 of 5 (permalink) Old 08-10-2004, 10:17 PM Thread Starter
4 Cam Bird's Avatar
Nevermind on the dielectric for sure, it is a silicone base and I know the other stuff definitely is not. Any other thoughts? I believe the bushing grease to be a Lithium base, can anyone confirm or deny that?
2011 CTS-V Wagon
post #4 of 5 (permalink) Old 08-10-2004, 10:41 PM
DirtyBird46's Avatar
Send a message via AIM to DirtyBird46
All I found out about the grease is it's "teflon enriched."
Energy Suspension Lube
You can get this stuff through Jeg's.
DirtyBird46 is offline
post #5 of 5 (permalink) Old 08-11-2004, 12:05 AM Thread Starter
4 Cam Bird's Avatar
Perfect, thanks.
2011 CTS-V Wagon
