Can't keep it straight - TCCoA Forums
post #1 of 29 (permalink) Old 09-06-2004, 09:11 PM Thread Starter
Angry Can't keep it straight
I need some help with a problem that I have been chasing for over a year now. The Bird wanders around on the road. It tracks straight but the least amount of uneven pavement and away it goes. You can't take your hand off the wheel for a second. I started with L & R new upper and lower control arms, new front and rear hub bearings on the passenger side, a couple of alignments, and new tires to no avail. The only thing I haven't replaced is the strut rod bushings and the driver's side bearings, and shocks. The tech said I need a camber kit for the passenger's side front but it was probably ok with a driver inside. I know it isn't the rubber steering joint and am wondering if it might be the rack or even the PS pump since I have the speed sensitive steering. I have replaced both sides tie rod end (inner and outer), and no improvement. I did find the rear toe lnks busted and replacement made no chnge there either. I am about ready to ditch it as bad as I hate the thought. Anything I missed?
97 Sport w/ 99 J-mod tranny
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
270K miles and still flying, just not daily!
Generalee is offline
post #2 of 29 (permalink) Old 09-06-2004, 09:20 PM
'Sounds like it doesn't have enough front caster. The more the caster, the more it wants to keep going straight.
johnaec is offline
post #3 of 29 (permalink) Old 09-10-2004, 10:45 PM
Air Force's Avatar
Send a message via AIM to Air Force Send a message via Yahoo to Air Force
i have the same annoying problem!!
Air Force is offline
post #4 of 29 (permalink) Old 09-10-2004, 11:14 PM
Fry Rice Specialist
Casper's Avatar
i thought i'm the only one.....
CarDomain Page
Casper is offline
post #5 of 29 (permalink) Old 09-12-2004, 05:46 PM
Me too... It got really bad once I put wide low-pro tires on it, though.
SloMo228 is offline
post #6 of 29 (permalink) Old 09-12-2004, 10:06 PM
Fry Rice Specialist
Casper's Avatar
that's what happen to me too. with the stock tires it is barely noticeable but after change to wider and lower profile....both my 94 and 96 have the same problem.
this may open up to a new world of discussion.
CarDomain Page
Casper is offline
post #7 of 29 (permalink) Old 09-13-2004, 09:03 AM
Same problem here and the car pulls left. My car is lowered and I run 255/45/17s. I have been all over this thing and can't find a problem. I have aligned it 4 or 5 times and set the caster 1/2 degree more positive on the passenger side and the camber 1/4 more positive on the drivers side, but the car still pulls right. Changing the alignment does not seem to have any real effect on it. I will take another look at the front suspension tonight (for probably the tenth time), but I have replaced the lower ball joints, strut bushings and LCA bushings. The only thing that helped was the lower ball joints because they were obviously bad. I think it is because either something is worn or bent or the car is too low and suspension has poor geometry at this ride height. It is hard to spot a bad balljoint in these cars because it is very hard to unload the front suspension. My method is to get jackstands as far out on the lower control arms as possible and then jack up the back end. Then try rocking the tire around with a six foot 2x4 in every direction. Lower ball joints seem to take a beating theses cars. That's my two cents worth....
stokasz is offline
post #8 of 29 (permalink) Old 09-13-2004, 06:52 PM
when I went to get my car aligned, the shop couldn't even get it in spec. They told me it had been in an accident. Imagine my surprise! I think I'd have noticed something like that
SloMo228 is offline
post #9 of 29 (permalink) Old 09-15-2004, 02:05 PM Thread Starter
I'm running stock tires etc, so thats not it. I am begining to wonder if the alignment shops are trying to sell more tires because they tried hard to sell me a new set claiming mine had bad belts. That mayhave been true as replacing two has helped but how long before I start seeing weird wear patterns and wandering again?
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
post #10 of 29 (permalink) Old 09-16-2004, 10:39 PM
I'm running the tires that came with the wheels...they're none too spectacular, and not in the greatest shape, so new tires might help. I wonder why they thought my car had been hit, though. Everything looks fine underneath...
SloMo228 is offline
post #11 of 29 (permalink) Old 09-20-2004, 02:22 PM
sometimes though you usually can't see everything until you yank the engine -
Remember the 1968 mustang project car for e-bay that foose did?
It had serious damage where they had to cut off and replace the entire front doghouse
vancouver83ltd is offline
post #12 of 29 (permalink) Old 09-20-2004, 02:42 PM
Prior to my suspension upgrade, my 94 would do the exact same thing. Before the upgrade I replaced the rear shocks and it helped a lot. Surprisingly so!!
Post-upgrade it is doing it again, but I have poly bushings everywhere (which makes everything “tighter” and the same cheap POS rear shocks (which I think have already gone to the great shock haven in the sky).
I have new shock, but I haven’t installed them yet.
69 F100 LWB w/460 Engine
post #13 of 29 (permalink) Old 09-21-2004, 08:46 AM
Dusty's Avatar
Have you checked your rear bearings? Both of mine went out and uneven pavement would make the car pull, jumping off the gas would cause it to pull. It bacame a 2 hands on the wheel driver. My wife thought I had too much too drink one night because on one road I was hard to keep off the center line. The passenger side was very noticable by jacking up the car and moving the tire around, not so much on the drivers side. This had been happening gradually, but was acelerated by change to 3.73 gear. With new bearings and hubs on both sides I can drive with my knee if I want too.
Dusty is offline
post #14 of 29 (permalink) Old 09-21-2004, 08:32 PM
hey, i have that problem, and i have to hlod my wheel to the lright a little to keep the car straigt, i replace every front suspension part, and it just moved it over the where i have to keep the wheel to the left to keep it straight
infectrus is offline
post #15 of 29 (permalink) Old 09-22-2004, 04:56 PM
well, I have the same problem - sorta' -
If I allow the steering to return on it's own, it won't go all the way to dead centre - rather it will be a little off to the side I was turning
i.e. made left turn, it's slightly off to the left
i.e. right turn slightly off to the right.
So maybe your steering might be doing this?
Just a thought, I really don't have any clue but it is possible that your steering may not be quite centred -
Who knows, your steering wheel might even be uncentered slightly?
Again, just some stuff to consider...
post #16 of 29 (permalink) Old 09-22-2004, 06:56 PM
I had the same problem. Lower the air pressure to 28-29 lbs and it helps alot.
post #17 of 29 (permalink) Old 09-23-2004, 01:08 AM
Fry Rice Specialist
Casper's Avatar
mine is opposite, it helps when i bump the pressure up...
CarDomain Page
Casper is offline
post #18 of 29 (permalink) Old 09-28-2004, 12:17 AM
yeah mine does the same ****! damn 17x9 rims 255/45s on em
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #19 of 29 (permalink) Old 09-28-2004, 05:01 AM
I figured I would post what I found was my problem: loose hub retainer nuts.
I blew a tire last week and when I was changing it for the spare I noticed that the tire had a good 1/4" of play. I thought the new bearings had somehow gone bad. But when I went to change them out I found out that the nuts were loose on both sides.
I tightened them up to the torque spec... again... and now it tracks great. (I have new nuts on order).
Just thought I would post my "discovery".
post #20 of 29 (permalink) Old 09-29-2004, 12:19 AM
Fry Rice Specialist
Casper's Avatar
what kind of torque wrench are you using?
CarDomain Page
Casper is offline
post #21 of 29 (permalink) Old 09-29-2004, 01:00 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
My g/fs '95 v-6 stang can grab an uneven spot in the road and SCARE the crap out of you. It has 17x9 cobra Rs. I think the rack is a little loose too, but I think the extra wide tires arent helping it any
-Rob
-Rob
Rob is offline
post #22 of 29 (permalink) Old 10-05-2004, 08:48 PM Thread Starter
No luck yet. The only thing I haven't replaced is the shocks, Rack, strut rod-frame bushings and the driver's side hub bearings. I am begining to think that the strut rods are the culprit as I've noticed I can spin the washer between the nut and shell. I'll check in later with results.
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
post #23 of 29 (permalink) Old 10-07-2004, 07:46 AM
I hear a clunking sound everyonce and awhile whats dat? Im thinking a balljoint mine be the cause of it all.. Basterd *** ****ing ford ****!!! GRRR
2004 F150
KrAzyT is offline
post #24 of 29 (permalink) Old 07-29-2005, 08:26 PM
Anyone ever find a solution? (sorry to dig up a dead post but this one is exactly my problem and had some hits already to it)
94birdnj is offline
post #25 of 29 (permalink) Old 07-29-2005, 09:06 PM
silentthunder's Avatar
I have similar problems as well, I have to keep the wheel slightly to the left to go straight, but for me, new suspension parts are in need. So after that I'll see if i still have the same troubles.
As far as a solution goes I think it will be different for everone since there are a lot of combinations of things that seem to cuase similar results for everybody.
silentthunder is offline
post #26 of 29 (permalink) Old 07-29-2005, 09:37 PM
Dusty's Avatar
Jack up the back of the car and see if any play in the rear wheels. Better yet, take off the tire and see if there is any play in the hubs. Like I said in up in this thread, sound like rear bearings. Very noticeable when both are bad, not that bad when just one.
Dusty is offline
post #27 of 29 (permalink) Old 07-29-2005, 10:33 PM
Silver95Bird's Avatar
First things first, if anyone EVER says anything about a camber kit for our cars, say thank you, and get out of there as quickly as possible. Clearly this tech has no idea how to align an MN12. Take it somewhere else.
My 95 used to pull ever so slightly to the right, we never did figure out why. It did it from day one until the end. I'm also interested to find out why.
Silver95Bird is offline
post #28 of 29 (permalink) Old 07-29-2005, 11:39 PM
Fry Rice Specialist
Casper's Avatar
i fixed mine. by changing the lower control arm and strut rod bushing. i'm thinking it's my strut rod bushing because my lower control arm is still very good at both side and my strut rod bushing are shot to hell.
i still change the lower control arm because i already bought the parts and already taken the old one out from the car and say damm, what a waste. since it's out, might as well change it. the strut rod bushing is another story, well, it's shot to hell.
CarDomain Page
Casper is offline
post #29 of 29 (permalink) Old 07-30-2005, 12:27 AM
Full Metal
RedThunder94's Avatar
my guess would be the strut rod bushings, if they are worn i would think you would loose some caster, somebody correct me if i'm wrong but since the strut rod bushings blew on my 92 it wanders all over the place.
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
