Tierod and ball joint replacement? - TCCoA Forums
post #1 of 5 (permalink) Old 09-08-2004, 04:55 PM Thread Starter
1. How hard is it to change Tierods and upper ball joints on a 93 T-bird?
2. Are there any special tools needed?
3. About how much would a shop charge to do it (both sides)
4. Any tips on replacing them? Because more than likely I will do it myself.
Thanks in advanced
-91 XR7
-92 Mercury Cougar
3.8 N/A for now!
-88 LX Mustang 5spd
GT40P Heads, FMS Ceramic Headers, Mac O/R H-pipe, Flowmasters, U/D Pullies, Ported stock intake, Steeda Tri-Ax shifter
Fastcat is offline
post #2 of 5 (permalink) Old 09-08-2004, 05:03 PM
Do a search, I've posted the easy way to do balljoints before. The key is an 18mm ratcheting wrench.
Rich95XR7 is offline
post #3 of 5 (permalink) Old 09-11-2004, 09:05 AM
Tie rods are fairly easy. The inner ones are a little annoying when threading the new one on. The joint is tight and you ca't go straight on and it will try your patience because you are holding the boot back out of the way. You may also need a small propane tourch to heat the spindle end to get it out easier. Usually leave the castle nut at the end of the rod and whack it with a good hammer. It is very important to measure the length of the rod from the center of the outer ball to the seat of the inside joint. You will be close enough to drive it to an alignment shop afterward. As for the Upper and lower ball joints, the uppers are easy except forgetting to the bolt under the brake booster. The lower control arm requires a little more muscle but it is not impossible.
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
270K miles and still flying, just not daily!
Generalee is offline
post #4 of 5 (permalink) Old 11-16-2004, 03:05 PM
You call that fairly easy?
Work needed to be done: Heater Core Replaced; Driver Door panel replaced; Right Inner tie rod replaced; Front suspension rotting away; Wire connection to the transmission melted from contact with exhaust.
TimberWolf is offline
post #5 of 5 (permalink) Old 11-16-2004, 03:17 PM
Dutch 4.6's Avatar
Dutch 4.6 is offline
