What front end bushing is this...quick! - TCCoA Forums
post #1 of 18 (permalink) Old 09-09-2004, 12:55 PM Thread Starter
MAMN12 Posse Member
JeffTBird93's Avatar
Ok, I'm a little clueless when it comes to exact names of bushings in the suspension. But I've been having this noise from my passenger side, and I had been thinking it was my shock. I did a little looking earlier and I found out it wasn't, but it's whatever this bushing is. What's this thing called so I can get it replaced ASAP! Thanks in advance....
~Jeff
*signed off
JeffTBird93 is offline
post #2 of 18 (permalink) Old 09-09-2004, 01:02 PM
bad93bird's Avatar
I beleive it is a rear strut rod bushing. If your gonna do 1 then do them all. Go to www.mn12performance.com and get them there. I did and can't complain.
bad93bird is offline
post #3 of 18 (permalink) Old 09-09-2004, 01:05 PM
that is a "strut rod bushing - control arm side" which should not be confused with
"strut rod bushings - frame side".
tbirdbrain is offline
post #4 of 18 (permalink) Old 09-09-2004, 01:07 PM
bad93bird's Avatar
True very true.
post #5 of 18 (permalink) Old 09-09-2004, 01:14 PM Thread Starter
MAMN12 Posse Member
How hard is it to replace, this is something I wanna get done quickly? I'll do the complete polyurthene set from mn12performance down the road a bit.
~Jeff
*signed off
post #6 of 18 (permalink) Old 09-09-2004, 01:17 PM
bad93bird's Avatar
If I'm correct, just loosen the nut and pull out the rod and replace the bushing. If you go to www.mn12performance.com it tells you how to do it. Can even download how to do it and print it out. Look at the bushings and click on instructions, I think.
post #7 of 18 (permalink) Old 09-09-2004, 02:00 PM
Rolling-Thunder's Avatar
Use the search feature here. It is not as simple as just loosening or removing a nut, and swapping them out.
I have posted detailed info. before on this subject, so you can do a search by my screen name.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #8 of 18 (permalink) Old 09-09-2004, 02:24 PM
Overkill Fetish Freak
"We got Bush`ing..."
-Nerds
Dr. FrankenCougie is offline
post #9 of 18 (permalink) Old 09-09-2004, 04:16 PM
BirdofPrey97's Avatar
LMAO......Dr. most people on here probably aren't even old enough when that movie came out and know how that saying should sound.........Guess they have the reruns.
Honor, Grace, and Dignity.....Do you remember these?
BirdofPrey97 is offline
post #10 of 18 (permalink) Old 09-09-2004, 04:32 PM
Whining Intakes Rock
Al_Florida's Avatar
Hey guys, wonder joints.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #11 of 18 (permalink) Old 09-09-2004, 05:20 PM
Chapter Director Coordinator
jamesD's Avatar
heh... classic.... and i'm a youngen (22)
jamesD is offline
post #12 of 18 (permalink) Old 09-09-2004, 06:41 PM
motor city poster
Red96Bird's Avatar
those bushings arent pressed in??? so after you take out the strut rod, you can just pull the old ones out (or in my case) lack there of old ones out), and just put the new ones in???
Red96Bird is offline
post #13 of 18 (permalink) Old 09-09-2004, 07:09 PM
Basically yes, but you have to pay attention to the position of the nuts on the strut rod, otherwise you will have to get the front end aligned.
post #14 of 18 (permalink) Old 09-10-2004, 08:06 AM
If the cars been running around without the bushing an alignment probably isn't a bad idea either way.
post #15 of 18 (permalink) Old 09-10-2004, 01:42 PM
is the bushing in Scott's pic the same as this part below:
2 - at LCA: K8680
http://www.rockauto.com/ref/Moog/Detail.html?K8680.gif
1994 Thunderbird - Renegade Racing Long block, TFHS Trans, NA/SVO intake. Cam94 lives!
2010 Shelby GT500 - Black/Silver
1995 Thunderbird LX - 2000 GT PI Swap by W&S Motorsports - Sold on Tccoa.
Bill H is offline
post #16 of 18 (permalink) Old 09-10-2004, 01:51 PM
Yup, the K8680 is the control arm side bushing set
the K8659 is the frame side bushing set.
why do I have to know these things! Thanks a lot moog!
post #17 of 18 (permalink) Old 09-10-2004, 02:08 PM
Sideoiler's Avatar
You have to know these things to enlighten dumb azzes like me!
Sideoiler
Sideoiler is offline
post #18 of 18 (permalink) Old 09-16-2004, 06:48 PM Thread Starter
MAMN12 Posse Member
Got bushings?
~Jeff
*signed off
