New front air ride deisgn {pic} - TCCoA Forums
post #1 of 8 (permalink) Old 09-09-2004, 10:57 PM Thread Starter
drag-aholic
BAGGED89's Avatar
its something i have thought about for a while but just finally got around to building. Why the lower arm/mount? To stabilize the lower arm. With the stock shock removed and just the bag in place it becomes becomes unstable and twists. So it is basicly an "A" arm now with 2 mounting locations.
if you want to see a few more pics HERE
1989 LX Full Air Suspension
BAGGED89 is offline
post #2 of 8 (permalink) Old 09-10-2004, 01:33 AM
Sideoiler's Avatar
So, what are the advantages in this setup? Pros & cons?
Sideoiler
Sideoiler is offline
post #3 of 8 (permalink) Old 09-10-2004, 10:33 AM Thread Starter
drag-aholic
BAGGED89's Avatar
advantages to having air? or this type of air set-up?
having air - none, IMO, other than being able to raise and lower the car
this type of air set-up - uses a normal bag and not having to buy $1000 shockwaves, a little faster, more lift
BAGGED89 is offline
post #4 of 8 (permalink) Old 09-10-2004, 11:22 AM
Looks good, have you done any flogging on it, to see how stable it is?
Rich95XR7 is offline
post #5 of 8 (permalink) Old 09-10-2004, 12:09 PM Thread Starter
drag-aholic
BAGGED89's Avatar
I don't know what you mean by "flogging".
I have driven it and so far so good. When i didn't have the lower arm it twisted and it wouldn't even lift so it couldn't be moved. So I think i'm ok. Some people just put the bag on the lower arm and it works for some . I think it is a function of how bad of shape your crossmember bushing is in. But I don't want it to twist when my new bushing goes bad.
its pretty stable - its a 7.5" long bolt at the crossmember now. its a 9/16 grade 8 which is a slight bit bigger than the metric 10.9 that was there. I had to run a drill through the bushing to "clean it out" so the bolt would fit through.
BAGGED89 is offline
post #6 of 8 (permalink) Old 09-10-2004, 12:57 PM
By "flogging", I mean spirited driving, not babying it over bumps and such.
post #7 of 8 (permalink) Old 09-10-2004, 01:00 PM Thread Starter
drag-aholic
BAGGED89's Avatar
oh - almost - i am still building trust in it now. my last air i beat the heck out of and it stayed together. i am still careful over things to listen and see hoe it goes. it has only been on there driving for about 4 days now.
BAGGED89 is offline
post #8 of 8 (permalink) Old 09-11-2004, 09:47 AM
BaggeD BoooosH's Avatar
Send a message via AIM to BaggeD BoooosH
looks good scott looks good
i need a new front the mark 8 isnt fast enough
BAGGED 97 lx 4.6L
"Original" Cobra R Ram air hood, xenon kit, 18" cragers, 245/45/18s, mac intake, jerry chip, u/d pulleys,and the little stupid crap
BaggeD BoooosH is offline
