$2000 Suspension upgrade! - TCCoA Forums
post #1 of 7 (permalink) Old 09-12-2004, 02:17 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Well yesterday I did a nice suspension rebuild with Koni adjustables, Eibachs, all new ball joints (control arms), bushings, inner and outer tie rods, and etc..
My suspension was SHOT! Both front spring where broken, all the ball joints and tie rods where shot, both rear shocks leaked all the gas out, and there where tons of destroyed bushings.
All I can say is that I love the way the car rides now. I have it as firm as they can get. I beleive I have read on here that the car will drop a little more in a few weeks, correct? Will it get any stiffer?
Next on my list of things to do after I fix my scrapping TC is bigger sway bars and some nice braces.
When I was doing the alignment I couldn't get the caster to adjust. I was trying to adjust it by that arm the comes off the subframe I believe and into the lower control arm. But it wasn't doing anything! It wasn't off by much, I just wanted it to be perfect since I had everything else perfect.
Anyways just sharing my thoughts on the suspension upgrade.
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #2 of 7 (permalink) Old 09-12-2004, 02:39 PM
JR Tigerstar's Avatar
Originally posted by Tony
All I can say is that I love the way the car rides now. ... Next on my list of things to do after I fix my scrapping TC is bigger sway bars and some nice braces.
It's like having a new car, isn't it?
Bracing is the "icing" on the suspension.
Upgrade the brakes & you'll be set to start adding more power and/or larger wheels & tires
JR Tigerstar is offline
post #3 of 7 (permalink) Old 07-06-2005, 08:59 PM
Thumbs up
what parts did you get? were from? I hope all poly bushings from mn12 and springs and shocks this winter (depending on when I go back too work) but what else should I get what about subframe bushings? do you have pics? sounds nice.
aceospades is offline
post #4 of 7 (permalink) Old 07-06-2005, 09:32 PM
Ya the eibachs will settle nicely. Just give them a couple weeks. If anything i think they get tab less stiff between that break in time.
MattsLE97 is offline
post #5 of 7 (permalink) Old 07-06-2005, 09:47 PM
When you do the braces would be interested in the details of where to get & your reaction to the ride. Just put in 1-1/4 rear sway bar this Thursday....beautiful. Next is struts & shocks, but more modest than yours, either KYB or ToKico's non adjustable. Have fun, Ed
big ed is offline
post #6 of 7 (permalink) Old 07-07-2005, 02:18 PM
4 Cam Bird's Avatar
No one makes anything for subframe bushings. and being that you live in illinois i am going to guess your car has seen some unfavorable weather for getting the subframe out to change the bushings. Meaning, its a huge pain in the *** to get the subframe out if you are in the midwest.
2011 CTS-V Wagon
4 Cam Bird is offline
post #7 of 7 (permalink) Old 07-12-2005, 06:47 PM
lol yea it wont be fun but I have too do it if I want the car too be nice. it will no longer see the bad weather after I'm done.
