Will Lowering Mess with my comfort? - TCCoA Forums
post #1 of 14 (permalink) Old 09-14-2004, 10:26 PM Thread Starter
Send a message via AIM to BeasTx
Hello, i wanted to know if i put some SpringTech lowering springs on my car..will it be all bouncy, or will it ride the same, increasing handling?
1995 thunderbird lx 4.6L-
gutted cats, flowmasters in rear
K&N, hypertech chip.
BeasTx is offline
post #2 of 14 (permalink) Old 09-14-2004, 10:30 PM
joshbea6's Avatar
Putting lowering springs on the MN12-Tbird/cougar/mark VIII body will not add bounce to your ride. It may stiffen things up a little, and DRAMATICALLY improve handling, but it will not make it more bouncy.
-Josh
joshbea6 is offline
post #3 of 14 (permalink) Old 09-15-2004, 04:49 AM Thread Starter
k, i just dont want it to be nasty on the highway.. ya know, like peoepl could still sleep while i'm driving ^^
BeasTx is offline
post #4 of 14 (permalink) Old 09-15-2004, 12:59 PM
Mine was lowered about 4.5 inches at one point, and still rode OK, so 1.5 inches would be nothing.
Rich95XR7 is offline
post #5 of 14 (permalink) Old 09-15-2004, 09:30 PM Thread Starter
cool ^^
BeasTx is offline
post #6 of 14 (permalink) Old 09-18-2004, 04:22 AM
Only thing that you have to be careful of is bottoming out now that you are lowered. You cannot enter driveways as fast as you could with the stock springs. If you are adding the lowering springs, I would recommend that you add the larger sway bars which will significantly improve the handeling.
AED 9 PSI Supercharger, .30 over Forged Block with Manley H-Beam Rods & Pistons, Innovative West 10% Overdrive Crank Pulley, Thump RRR Tensioner Pulley, Cobra Crankshaft, BPE Racing Stage 2 Ported & Polished Heads, Crower Direct Replacement Cams, 70MM Throttle Body, MAC Cold Air Intake, 80 MM L-MAF, 38Lbs Injectors, JBA Ceramic Coated Headers, Metal Matrix Drive Shaft, Kevlar Clutch & Kolene Reaction Plate Transmission, True 2.5" Dual Magnaflow Exhaust (Cats & Mufflers), Griffin 1 1/4" Radiator, B&M Racing Trans Cooler, Hughes 2750 Stall Torque Converter, 3.73:1 Gears with Traction Lock Differential, Trans-Go Kit, Superchips Custom Tune for Supercharger, 17" SVT Wheels, Kenny Brown Suspension Enhancers & Eibrach Lowering Kit.
Wolverine27 is offline
post #7 of 14 (permalink) Old 09-18-2004, 04:40 AM
Banned
the lower you are to the ground the more stable it is...or the lower your center of gravity....o wait....or was it um....GAH!!
Porkchop is offline
post #8 of 14 (permalink) Old 09-18-2004, 06:13 AM
I have these springs, dropped about 2.25 inches the first day, and have continued to settle to about 2.75 so far.....
I love my springs.......
Dave
DMcBrideBoston is offline
post #9 of 14 (permalink) Old 09-18-2004, 07:58 AM
So the ST are actually lower than advertised? Got a Pic? I'm in the market for a new set of springs right now.
post #10 of 14 (permalink) Old 09-18-2004, 08:30 AM
post #11 of 14 (permalink) Old 09-18-2004, 10:14 AM
Johnny Bling Bling
93 lx's Avatar
no bouncy
increase handling
rougher ride. i have the v6(not as big as v8 drop) eibachs mated to kyb's, and it is a lot less comfortable than stock, but i guess the handling payoff is worth it. and it looks REAL nice!
2009 Ford Flex Limited AWD
93 lx is offline
post #12 of 14 (permalink) Old 09-18-2004, 11:30 AM
JustinH's Avatar
with my combo (bilsteins, vogtland springs, addco big bar), the ride is very very stiff.
I like it though. It doesn't ride like a couch, it rides like a much sportier car than mother ford intended.
JustinH is offline
post #13 of 14 (permalink) Old 09-19-2004, 01:26 AM
terraplane8's Avatar
I have Eibach's (as of 6 months ago)and Tokico Blues (as of 4 years ago). They work really well together, IMHO. Not any noticeable difference to me in the ride from the stock mushy LX springs and Tokicos, but the drop isn't that large, either. Looks like what it SHOULD have looked like from the factory.
Ditto the comments about speed bump bottoming, curbs, etc. And your alignment will be off after the install, guaranteed. It should be able to be corrected, but the alignment shop will actually have to more than just check the toe, so you need to be upfront with them about getting it done right.
Good time to set aside some extra cash for upper control arm/balljoint assemblies, if you have any miles on yours. My upper balljoints and lower control arm-to-strut arm bushings were toast. Unless you have good shocks/struts already, now is a good time to do them as well. And don't forget to get the new lower strut bolts/nuts, and upper spindle pinch bolts/nuts.
Submariners do it deeper...
terraplane8 is offline
post #14 of 14 (permalink) Old 09-23-2004, 08:20 AM
Dusty's Avatar
I had both Addco bars, Tokico Blues and SC springs. Going to the Vougtland springs lowered the car and increased handling. Going over potholes is much more noticeable now. My wife complains about that when she rides with me. Fortunately we have pretty good roads here so not a big deal to me. I now bottom out sometimes and hit on tall parking curbs. It hits where the JL SFCs attach to the front. I have 245/50-16 tires that are an inch in diameter smaller than stock. I plan on putting on taller tires next time. I think that half an inch will make a difference.
Dusty is offline
