Lowering with 255's - TCCoA Forums
post #1 of 10 (permalink) Old 09-16-2004, 05:55 PM Thread Starter
motor city poster
Red96Bird's Avatar
Lowering with 255's
Ok i dont want people heard or think...i want the truth.... im tired of people saying "yea it will rub", with no experience....
simple question, i currently run 255/45/17's on my car with y2k cobra R's 17x8.5, with a 36mm offset. (currently no rubbing)
however this fall/christmas im recieving a set of lowering springs, the drop is at 1.5 inches, with that do i have to worry about the tires rubbing at any point??
thanks,
patrick
Red96Bird is offline
post #2 of 10 (permalink) Old 09-16-2004, 06:43 PM
Depends on the offset, I guess, because I knew people running 275/40/18's with no rubbing problems on lowered cars.
Rich95XR7 is offline
post #3 of 10 (permalink) Old 09-16-2004, 07:55 PM
I'm running 255/50's on 17x71/2'' Scoundrels and had to use spacers in front, even before the Eibachs, but no rubbing. Hope to see you guys on the 26th(with MY red '96 'bird)lol.
MiBird96 is offline
post #4 of 10 (permalink) Old 09-16-2004, 08:02 PM
392Bird's Avatar
BFG 255/45/17 and 275/40/17 , cut Eibachs no rub.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #5 of 10 (permalink) Old 09-16-2004, 11:00 PM
Fry Rice Specialist
Casper's Avatar
will let you know once going in my car....
CarDomain Page
Casper is offline
post #6 of 10 (permalink) Old 09-17-2004, 09:39 AM
4 Cam Bird's Avatar
My Bullitt wheels rubbed BAD, even with the lip pounded up they rub a lot with weight in the back of the car. But I think they are 32 MM offset and I am also running 255/45/18's so they are slightly taller. My old wheels and tires were 255/??/15's and also rubbed but the wheels were on the car when I got it and I have no idea of the offset.
2011 CTS-V Wagon
4 Cam Bird is offline
post #7 of 10 (permalink) Old 10-03-2004, 09:09 PM
Send a message via AIM to DGFourSixLX
I run 17x7 wheels with 255/45/17 tires and have not experienced any rub.
'07 Toyota FJ Cruiser
(Sold)1997 Lincoln Mark VIII LSC Black/Black
Chrome Cobra R's, BFG Rubber, Cobra/KVR Brakes
Custom Koni front air struts, Bilstein/Addco in rear
Cobra Intake Manifold, SCT XCal by Lonnie of BOC
DGFourSixLX is offline
post #8 of 10 (permalink) Old 10-05-2004, 06:20 PM
I've got 255/45 R 17's on 17x9 cobra R's and I've got less than a 1/4" of clearance between the tire and the sheet metal in back when the tires are tucked in the wheel well (when the trunk is loaded with my DR's and floor jack)
rancherlee is offline
post #9 of 10 (permalink) Old 10-06-2004, 09:12 AM
I am running 225/50/17 on my 17x9 2003 Cobras. The problem with mine is; on the SC with the Tokicos, the width of the wheel allows the fenders (front and rear) to come directly down on the tire under those heavy suspension movements. On the LX they work great. Sprint springs with the Mark LCAs and Slayer’s perches hold the rear a little high for my tastes but have not rubbed once. I have yet to make a trip thought the canyon yet. I will try to get a picture up tonight. Here is the SC with my rear spring spacers installed to hold up the rear.
click
-M
Mickey is offline
post #10 of 10 (permalink) Old 10-06-2004, 05:36 PM
97' LX, Tokia springs and shocks, 17x7.5 rims with 39mm o/s, 255/45/17 tires (26.1 OD), stock alignment. Great stance, enough wheel well opening, no rub, and you're riding on rails. The 255/45/17 tires are shorter than stock, they need to be matched with the lower springs and shocks. Don't look back. Ed
Hollywood Ed is offline
