suspension change is PITA!!! - TCCoA Forums
post #1 of 24 (permalink) Old 09-22-2004, 12:41 AM Thread Starter
Fry Rice Specialist
Casper's Avatar
just change the front today with a spring compressor bought from autozone and work by my self. let me tell you guys also that the front is PITA!!! the upper mount have to line up, the whole assembly is heavy, couldn't take out the endlink, so just disconnect upper control arm ball joint bolt and nut, wiggle here and there...all by my self. definitely will not want to do it again.
also replace driver side upper control arm and the ball joint is pretty bad, too much play in it. easier to change than i thought.
also notice the lower control arm bushing is pretty much shot, but that will be next time.
tommorrow morning will change out the rear. wish me luck!!!
CarDomain Page
Casper is offline
post #2 of 24 (permalink) Old 09-22-2004, 01:07 AM Thread Starter
Fry Rice Specialist
Casper's Avatar
also the passenger side the spring also broke.
CarDomain Page
Casper is offline
post #3 of 24 (permalink) Old 09-22-2004, 07:51 AM
Hmmmm, I've never had that much of a problem. It's all in having the right tools for the job. I'd never do it with those spring compressors, but I have a wall mounted compressor. The endlinks aren't that bad, you just have to play with the floor jack to find the spot where there is no pressure on them, and either tap them out, or use a small pickle fork.
Rich95XR7 is offline
post #4 of 24 (permalink) Old 09-22-2004, 02:20 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
i gave up on the rear spring change!!! just manage to change the rear shocks and will let the shop do the spring sometime next week. there is no way i can wiggle out the spring. my hand and my muscle already being pushed to the limit. don't want to deal it anymore. the perches prevent it from coming out. use the spring compresor doesn't help either.
CarDomain Page
Casper is offline
post #5 of 24 (permalink) Old 09-22-2004, 03:30 PM
Sounds like you are making things waaaaaay too hard. The rear springs are very easy to do, just take your time, and look at things. I've never used a spring compressor on the rear.
I've had the best luck with getting the car up as high as you can on the jackstands, disconnecting the brake line from where it meets the hardline, and taking the bracket off of the fenderwell. Then put a jack under the control arm. Disconnect the swaybar endlink, the shock, and the upper control arm from the spindle. Then I just push down on the lower control arm with my foot while I slide the spring out. I've done about 5 this way, and can change rear springs in about 30 minutes. Wes's car was most recent, and we took his out, cut them, and put them back in in under 45 minutes. If you did the fronts, the rears should be a walk in the park.
post #6 of 24 (permalink) Old 09-22-2004, 03:33 PM
FordFanatic's Avatar
i agree, i rather change 100 rear springs out than have to do the fronts. not that they are that much harder, just that the rears are so easy.
FordFanatic is offline
post #7 of 24 (permalink) Old 09-22-2004, 03:39 PM
Back in Black
ShadowDragon's Avatar
We did my fronts with the rented spring compressors and the rears pretty much like Rich described. Wasn't hard at all. Once you get everything disconnected just push with your foot and pull on the spring.
ShadowDragon is offline
post #8 of 24 (permalink) Old 09-22-2004, 03:40 PM
OH, and don't forget to bleed the brakes if you take the line apart.....lol
post #9 of 24 (permalink) Old 09-22-2004, 03:52 PM
I agree to the back is a piece of cake. I thought i was much easier than the front. Once you get one side off you kinda learn your routine for the other side and it goes quickly.
MattsLE97 is offline
post #10 of 24 (permalink) Old 09-22-2004, 09:49 PM
Rolling-Thunder's Avatar
CAsper, you're doing something wrong. The rear springs are so easy to remove, and do not require any spring compressor.
Check out this link
http://www.mn12performance.com/mn12h...ng_springs.htm
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #11 of 24 (permalink) Old 09-23-2004, 01:06 AM Thread Starter
Fry Rice Specialist
Casper's Avatar
i'm so stupid!!!
i disconnect the upper mount bolt and the rotor re hitting on the ground that's why it limit the movement. from that article i need to unbolt the lower one. that makes sense. oh well, will do it next week so i just swap out the shocks only. now my car front end drop and the rear end as high as sky.
ps: got sunburn too!!!
CarDomain Page
Casper is offline
post #12 of 24 (permalink) Old 09-23-2004, 07:36 AM
I always unbolt the top one, and just put the car as high on the jackstands as possible. I've seen people do it both ways, it just seems easier to me to undo the upper control arm from the spindle.
post #13 of 24 (permalink) Old 09-23-2004, 09:44 PM
MAMN12 Posse Member
JeffTBird93's Avatar
I just finished putting on my Eibach's and Tokico's on the front earlier this evening. I've never messed with anything dealing with the shocks or struts...and it only took me about 2½ hours at a comfortable pace.
~Jeff
*signed off
JeffTBird93 is offline
post #14 of 24 (permalink) Old 09-23-2004, 11:07 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
i'm sending my car to tuffy this saturday morning to get the rear spring swap out and i'm gonna pay 160 bucks for it. i know it sucks but i really don't have the time already and will not want to deal it again. my muscle are pretty hurt now and when try to pull out the spring the jack fail and the car fell sideways towards me. scare the hell out of me. have to cycle to autozone to buy new jack to lift up the car again!!!
makes me harder to work also.
CarDomain Page
Casper is offline
post #15 of 24 (permalink) Old 09-23-2004, 11:09 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
also my front end will dive easily and rub. the sport shock is softer than i thought!!!
CarDomain Page
Casper is offline
post #16 of 24 (permalink) Old 09-24-2004, 07:46 AM
I know you weren't working on your car with just a jack under it Jackstands are a necessity in life.....That is keeping your life.
post #17 of 24 (permalink) Old 09-24-2004, 09:44 AM
MAMN12 Posse Member
So let me get this straight...
I won't have to disconnect the brake lines to get the rear spring out?...just plug and play so to speak? If so, I've got 3 hours before I go to work today, might try to get it done.
~Jeff
*signed off
post #18 of 24 (permalink) Old 09-24-2004, 10:01 AM
Back in Black
Correct, Joel and Mike and I did it in Joel's driveway and didn't disconnect any brake lines.
post #19 of 24 (permalink) Old 09-24-2004, 10:05 AM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
The rears be easy mon! Just relax... If you can do the fronts, you can do the rears with a few beers in ya.
Here's some inspiration...
I didn't need to remove my lines, I just Zip Tied the calipers outta the way...
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #20 of 24 (permalink) Old 09-24-2004, 01:25 PM
MAMN12 Posse Member
Well, that wasn't too bad...only 2 hours. Looks good too, no more 4x4 look. Pics to follow within a day or two. Oh, and, no beer, gotta work at 3.
~Jeff
*signed off
post #21 of 24 (permalink) Old 09-25-2004, 12:03 AM Thread Starter
Fry Rice Specialist
Casper's Avatar
i did use floor jacks under it. the thing is when i need extra lift for the lower control arm to swing down more so i can pull the spring out i use the jack and lift up more and forget to lift the floor jack to support it so the rear end is only being support by the regular jack. then i go ahead and pull the springs and thus a little bit of rocking motion which cause the jack to fail. i was litterally sitting at the side straightaway with my whole body shivering while litting up a cigarette. almost lost my foot!!! i sit there couldn't stand up for about 10 minutes there. shivering so bad.
also sunday is the michigan meet and i don't have extra time to do this so just send to shop.
CarDomain Page
Casper is offline
post #22 of 24 (permalink) Old 09-25-2004, 12:33 AM
Whining Intakes Rock
Al_Florida's Avatar
They seem to fail at the worst times too.
4-ton took a dump.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #23 of 24 (permalink) Old 09-25-2004, 09:27 AM
Yeah, the question is: Is your life worth $15?????????
http://www.sears.com/sr/javasr/produ...Lift+Equipment
post #24 of 24 (permalink) Old 09-27-2004, 03:13 PM
MAMN12 Posse Member
Pics of the drop....much better now...
Before...
After...
Yes I know it's dirty.
~Jeff
*signed off
