Subframe connectors vs Strut tower braces - TCCoA Forums
post #1 of 27 (permalink) Old 09-23-2004, 07:30 PM Thread Starter
I've decided that I wanna start modding my 'Bird a bit, and the first thing on the list is chassis stiffening. I really don't know how stiff our cars are, although I'm pretty sure they're not as bad as a Fox-chassis car.
I've seen some pics of JL's bracing, and man that's alot of material. I'm gonna be using the car for touge and maybe an open track event or 2. The biggest amount of power I ever figure putting into the car would be around 250-260 fwhp, and that's if I do the Explorer swap. My budget for the bracing is around 150 bucks. So do I need all that bracing, or would some subframe connectors and strut-tower braces work? Also, which would improve the car's handling the most, subframe connectors or the strut tower braces?
JL check your PM's.
V8Tsunami is offline
post #2 of 27 (permalink) Old 09-23-2004, 09:18 PM
If you're going to do the suspension, I'd go with springs and shocks first. But I'd imagine that the subframe connectors would stiffen up the car more than the shock tower braces, for what it's worth. BTW, our cars have shocks, not struts. It's a common mistake, so don't worry about it.
SloMo228 is offline
post #3 of 27 (permalink) Old 09-23-2004, 09:37 PM
And you won't get subframe connectors for $150. You can get the front STB for that, maybe, and definately get the rear for that and have some left over. I would start with the front or rear first, or save some more money for the subframe connectors.
Rich95XR7 is offline
post #4 of 27 (permalink) Old 09-24-2004, 06:07 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Rich is right....
Start with the STB's first if you've only got $150 to use right now,and then to finish it off,a set of subs will do the job.
JL
Fuelly
Johnny Langton is offline
post #5 of 27 (permalink) Old 09-24-2004, 06:48 PM Thread Starter
That sounds good. I don't know much about which parts of our cars flex the worst, so I didn't want to brace one part of the car when another area needed it the worst.
So JL, how much would it be for 1 set of front and rear stb's, including shipping? I live in southern Illinois.
post #6 of 27 (permalink) Old 09-24-2004, 07:29 PM
I'm not making any fronts right now,and dunno when I'll be making any soon.
The rear will be $80 shipped.
JL
Fuelly
post #7 of 27 (permalink) Old 09-30-2004, 08:47 PM Thread Starter
Well let me know if you start making any. I'd really like to have one of those. But I know people have more important things to do in life than make car parts for complete strangers so I'll wait for a while till you can get around to making them again.
Just don't stop making them before I get one though
post #8 of 27 (permalink) Old 09-30-2004, 09:13 PM
I'm actually making them now-My friend that helps with the STB's is back from his job out of state,and he's ready to make a run of front STB's
JL
Fuelly
post #9 of 27 (permalink) Old 10-04-2004, 03:44 PM Thread Starter
Cool. How much for a set of front & rears shipped? Could you type some simple instructions so I know exactly how to do it? I know this is a pretty simple project but I still want to take my time to get it right.
I assume the car needs to be level on jackstands to do this, and what point of the car would I use to determine if it's level or not, both front to rear and side-to-side?
post #10 of 27 (permalink) Old 10-04-2004, 04:55 PM
Yeah, I too would like to know how much a set shipped would cost. My '97 has the 3.8, so I don't know if that makes a difference as to whether the front brace will fit or not. Thanks.
bcook_84 is offline
post #11 of 27 (permalink) Old 10-04-2004, 05:00 PM
The STB install is pretty much idiot proof.
The front uses a couple of existing holes,and you also need to drill a few.It doesn't matter if the car is level or not-I'd just suggest it have all four wheels on the ground loaded.
The rear is a bit more flexible-you can place it on the rear shock towers where it fits your car best(and where it may clear your stereo,etc),drill 2 holes,and bolt it in.
That simple.
The front is only guaranteed to fit a 4.6L car-sorry,no 3.8L bars.
The rear fits any MN12.
Front STB=$150
Rear STB-$75
Shipping varies dependant on your address,and how many pieces you need at one time(I package parts in the same box for savings on shipping when possible).
JL
Fuelly
post #12 of 27 (permalink) Old 10-04-2004, 06:37 PM
Maic's Avatar
hey that sounds god to me too. JL i will PM you.
MAIC
Maic.
Maic is offline
post #13 of 27 (permalink) Old 10-06-2004, 02:28 PM
PCD
Confirmed V6 Nut
JL,
I know you don't guarantee fit for anything but a 4.6L on the front STB, but is it possible average joe could modify your STB to fit around a 3.8/4.2L motor? I got a brother that is a millwright.
PCD is offline
post #14 of 27 (permalink) Old 10-06-2004, 03:40 PM Thread Starter
Thanks for the info JL. Pm me so I know how to order one.
post #15 of 27 (permalink) Old 10-06-2004, 04:16 PM
Originally posted by PCD
JL,
Anything is possible,and it's possible that it'll fit without any mods.I don't have any 3.8L cars around to test fit on,and have no desire to go find one or make arrangements to test fit one..
JL
Fuelly
post #16 of 27 (permalink) Old 10-06-2004, 08:55 PM
I could make one for a V6, if someone can bring their car up here. I'm working on one for a SC right now. I'm not too interested in mass producing 4.6 ones if Johnny is making them again.
post #17 of 27 (permalink) Old 10-07-2004, 04:05 AM
JL...Are you still making the subframe connectors? Will these help out at the track much, or mainly for street driving?
Dave
DMcBrideBoston is offline
post #18 of 27 (permalink) Old 10-07-2004, 05:52 AM
Dave
Yep-we're making everything again.
They help everywhere.Solid track launch,and less flex for street driving as well.
JL
1997 Thunderbird-4.6L/4R70W.....12.[email protected]
Fuelly
post #19 of 27 (permalink) Old 10-07-2004, 11:50 PM
Rich95XR7,
Would a brace for a 3.8 SC be able to fit over a 3.8 NA? I'm not expecting a definite answer, just looking for a guess as to what might fit because I live in Indiana, so I can't really bring my car down for a custom brace for a 3.8 NA. I'm not even talking an exact fit, just something that would clear everything and still let me close the hood. Thanks.
bcook_84 is offline
post #20 of 27 (permalink) Old 10-08-2004, 08:16 AM
I don't think that it will fit, but I'm not sure. There are a couple OK TCCoA members that have 3.8's, and if there's enough interest in them, and I can get 10 orders prepayed, with the first of them being from Oklahoma or Texas, I will do them.
post #21 of 27 (permalink) Old 10-08-2004, 01:20 PM
OK, sounds good. I guess I will just have to cross my fingers and hope someone in your area with a 3.8 has an interest. If you do end up making it, though, I will be one of the first to sign up to order. Thanks.
bcook_84 is offline
post #22 of 27 (permalink) Old 10-13-2004, 05:52 PM
JL,
I am just starting to modify my 96 Lx 4.6 This thread has some interesting possibilities to start from. Do you have a web site or how do I get more info?
Chris
Chris Sr. is offline
post #23 of 27 (permalink) Old 10-14-2004, 11:52 AM
The Band, not the Disease!
AnthraxBird's Avatar
Make your own subframe connectors.... I hope your good with a welder, and a tape measurer.. =)
AnthraxBird is offline
post #24 of 27 (permalink) Old 10-14-2004, 12:29 PM
SplitPortBird's Avatar
Can someone supply me with a good pic of the JL STB brace installed? I want to see if the 4.6L version will clear my engine (4.2L engine with either F-150 or Mustang intake)
Or if it wont,, it'll give me a good Basis on where to begin building my own.
Brad M
SplitPortBird is offline
post #25 of 27 (permalink) Old 10-14-2004, 02:20 PM
281_TBird's Avatar
Does this STB clear an MAC cold air?
1997 Ford Thunderbird, Built NA 2V/ T-45
1997 Ford Explorer AWD 5.0L
2003 Lincoln LS V8 Bolt Ons
2009 Yamaha VMax
2011 F-150 Lariat Limited 6.2L 4WD
2015 Ford Mustang GT Premium, Performance Pack, Recaros
281_TBird is offline
post #26 of 27 (permalink) Old 10-14-2004, 07:32 PM
I don't know.It clears the OE tube with a bit of room left over.
JL
Fuelly
post #27 of 27 (permalink) Old 10-14-2004, 10:07 PM
281_TBird's Avatar
I think Ii'll give it a try, but I won't be able to get one for a few months, so I'll buy the front and rear braces next time you make a batch. Thanks.
2009 Yamaha VMax
