Shorter End Links? - TCCoA Forums
post #1 of 3 (permalink) Old 09-23-2004, 09:46 PM Thread Starter
MAMN12 Posse Member
JeffTBird93's Avatar
Shorter End Links?
I've read about the problems with the end links and lowering the back end of these cars. According to the tech articles, I need to find some of these shorter end links that are apparently made by Addco. Is this an absolute must to make the rear drop like it should, and where can I get these endlinks? Thanks in advance.
~Jeff
*signed off
JeffTBird93 is offline
post #2 of 3 (permalink) Old 09-23-2004, 11:26 PM
The straight up answer is "ONLY WITH AFTERMARKET SWAYBARS" does the shorter endlinks become necessary. I was probably lower than any MN12 without bags at one point, and had factory endlinks with factory bars. 4.5 inches lowered to be exact, and had no problems.
Taken from a post in a lower thread by Rich
This awnsers it for you
Dave
DMcBrideBoston is offline
post #3 of 3 (permalink) Old 09-24-2004, 01:01 AM
i read same thing and got the shorter endlinks, didn't see any difference, and my aftermarket links don't have the rotating couple at the end so they just bent
XR7kid is offline
