Bushing Kit - TCCoA Forums
post #1 of 4 (permalink) Old 09-24-2004, 12:35 PM Thread Starter
doug's Avatar
Bushing Kit
There are poly bushing kits available for our cars.
Are they worth the price?
How difficult is it to install the parts?
What if any are there any problems?
Doug
doug is offline
post #2 of 4 (permalink) Old 09-24-2004, 01:03 PM
The Great Obucina's Avatar
front and rear suspension bushing kits.
www.mn12performance.com
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 4 (permalink) Old 09-24-2004, 01:33 PM Thread Starter
doug's Avatar
Thanks, but I know they are available.
I had the following questions:
Doug
doug is offline
post #4 of 4 (permalink) Old 09-24-2004, 02:56 PM
girdnerg's Avatar
Depends on the ride you want. Polly wil be stiffer and last longer but make alot of squeaking. Rubber will give the cushy factory ride and will rot eventually.
The link he gave you also has installation instructions. I would read through them and judge the difficulty based on your skills and if you have the right tools. Pulling a tranny with a lift and tranny jack is easy. Doing it in my driveway on jackstands and a floor jack is NOT easy.
I just put in the www.mn12performance.com polly front anti-sway bar bushings and could feel a huge difference in body roll. My stock rubber ones weren't worn out, but I had the engine out and replaced them anyway.
Hope this helps,
Rob
girdnerg is offline
