How long do balljoints last? - TCCoA Forums
post #1 of 7 (permalink) Old 09-29-2004, 08:59 PM Thread Starter
wilson502's Avatar
Did a search, and found nothing, What is the life of the upper and lower balljoints? How can you tell if they are bad?
2007 White Ford Focus SE ZX3 Hatchback (The new driver)
1997 Alpine Green 4.6L Bird (SOLD!)
Mods:
Removed Air silencer, Clear Corners, Silverstar headlights and corner lights, Moroso Bluemax Spiral Core wires, Custom 3" Magnaflow exhaust with 2.5" Y-Pipe, 300-450 HP J-mod Kit by dirtyd0g , Hayden 30k GVWR Trans Cooler, Sport Front Suspension, 03-04 Cobra Rear Shocks, PBR Front Brake Swap, Xcal 2 by Lonnie @ Blueovalchips.com, 22C plugs, 180F T-stat, 02GT MAF/Airbox with K&N Drop in, Griffin Radiator, Cobra Water Pump
wilson502 is offline
post #2 of 7 (permalink) Old 09-29-2004, 09:57 PM
PCD
Confirmed V6 Nut
From experience you hear a rubber slowly slipping on metal sound. You may feel the front tires not riding flat on the tread after the turn. If you really let the ball joint go, the wheel collapses into the fender well.
PCD is offline
post #3 of 7 (permalink) Old 09-29-2004, 10:08 PM
FordFanatic's Avatar
if they have been bad for any time you might notice some wearing on the outside of your tires.
FordFanatic is offline
post #4 of 7 (permalink) Old 09-29-2004, 10:31 PM Thread Starter
wilson502's Avatar
hmm, would it make a sound, if i bounced the front end of the car up and down? like putting pressure on it?
Mods:
post #5 of 7 (permalink) Old 09-29-2004, 10:52 PM
THNDRN 1's Avatar
I just replaced my lower ball joints at 109k on my 94 and the passenger side had 1/8" play in it. My last bird lost the lower driver side ball joint at 160k. And my cousin lost his lower joint at about 150k. I recomend a replacement for the front lowers not much after 110k atleast!
THNDRN 1 is offline
post #6 of 7 (permalink) Old 10-05-2004, 09:37 PM
JNT
JNT's Avatar
I'm just over 100k on mine. The upper ball joint on the driver side is damaged and making noise. I don't see anything on the passengers side but I'm going to replace both.
1997 Thunderbird 4.6L LX (out of commission for now)
SCT XCAL 2 From Lonnie, 02 Mustang MAF and air box, Dynomax Cat Back Exhaust, Steeda U/D Pulleys, 70MM FRPP TB, Dual Piston Calipers, KVR Rotors, Alpine CD, Polk Speakers
1996 Thunderbird 4.6L LX Stock
1994 Thunderbird SC (Needs Work, for sale)
1996 Bronco XL - 2003 Escort ZX2 wrecked - 1996 Bronco XLT Sport
Project Car: 69 Lincoln Continental
JNT is offline
post #7 of 7 (permalink) Old 10-06-2004, 01:02 AM
Refrigerator Raider Hater
GreenBird's Avatar
I'd say 75K to 100K is the normal life expectancy of a balljoint. I've replaced 7 on three of my birds.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
