Front passenger suspension clunk - TCCoA Forums
post #1 of 4 (permalink) Old 10-09-2004, 07:16 PM Thread Starter
Paddycake's Avatar
*&%*^%(^%*&^ Front end!!!!!!
Front end noise again. Nice clunk on the passenger side when parking and making slow turns.
This is time 4 for the Strut rod bushings inner and outer(both sides WTF right!).
I used Ford parts every time who makes better(or heavier duty/severe duty) front end parts for our cars?
No matter how good she looks. No matter how cool she is about your "stuff". No matter how great she is in bed, someone somewhere is sick of her crap.
1995 850R with 18T, 3" downpipe, R.I.P. kit, ported intake,42lb injectors, N/A cams, 960 throttlebody, Rica tune(15psi in first and second 17psi in third and fourth). Bilsteins all around, V70R caliper and rotor upgrade, total lack of traction. IPD STB, Ultra Racing lower braces and RSTB.
Paddycake is offline
post #2 of 4 (permalink) Old 10-09-2004, 07:24 PM
jk69cat's Avatar
now i would look to make sure its not something else, liek the control arms , ball joints, or tie rod ends. it could also be the lower radius rods where they go thru the front of the subframe as well . they arent as common as the rears but they still do go bad too .
mn12 less!
jk69cat is offline
post #3 of 4 (permalink) Old 10-09-2004, 08:02 PM Thread Starter
Paddycake's Avatar
accually I have looked and as far as I can see the stock crap that I replaced everything with is still OK no other issues. But since I'mgoing back in I might as well go in STRONGER.
post #4 of 4 (permalink) Old 10-10-2004, 08:27 PM
ZackG's Avatar
haha i have the SAME exact noise. I just dont care to get it taken care of.
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
