Special tools? - TCCoA Forums
post #1 of 7 (permalink) Old 10-15-2004, 02:42 PM Thread Starter
The Band, not the Disease!
AnthraxBird's Avatar
Special tools?
Will I need any special tools for new front and rear shocks and springs? What all will I need, (sizes)???
AnthraxBird is offline
post #2 of 7 (permalink) Old 10-15-2004, 06:21 PM
Rolling-Thunder's Avatar
Tools needed for rear spring/shock replacement
Trolley jack
Jack Stand
Lug wrench
Locking lug nut key
Penetrating fluid
White lithium grease
9mm socket bit
13mm deep socket bit
18mm socket bit (1/2” drive)
18mm comb. wrench
21mm socket bit (1/2” drive)
21mm comb. wrench
½” lug breaker bar.
Haven't done the fronts, but maybe someone else can post that.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #3 of 7 (permalink) Old 10-15-2004, 11:52 PM
Fry Rice Specialist
Casper's Avatar
forget the "cursing" out. you need it too.
CarDomain Page
Casper is offline
post #4 of 7 (permalink) Old 10-15-2004, 11:53 PM
Fry Rice Specialist
Casper's Avatar
Trolley jack
Jack Stand
Lug wrench
Locking lug nut key
Penetrating fluid
9mm socket bit
18mm socket bit (1/2?drive)
18mm comb. wrench
21mm socket bit (1/2?drive)
21mm comb. wrench
½” lug breaker bar.
"Cursing"
CarDomain Page
Casper is offline
post #5 of 7 (permalink) Old 10-16-2004, 12:03 AM
That's a required tool for almost any job. I don't think I could do a job without it!
SloMo228 is offline
post #6 of 7 (permalink) Old 10-16-2004, 12:34 AM Thread Starter
I can't get the DAMN bolt out of the bottom shock... it connects the LCA and the shock.. i got the nut off, but the BOLT won't come out!!!!!!!!
post #7 of 7 (permalink) Old 10-16-2004, 12:58 AM
i usually stick screwdriver between the mounting points (space above lca where shock mounts too) and give it a twist. sometimes theres tension on it that'll keep bolt in there tight
XR7kid is offline
