Check this site out - TCCoA Forums
post #1 of 24 (permalink) Old 10-16-2004, 08:39 PM Thread Starter
46cougrrr's Avatar
Check this site out
Comparisons between our suspensions and 03 Cobra IRS Suspensions
Gives me ideas.
DD: MG 03 Cobra, 21psi M122 (GT500) blower swap
99 GT Auto Roller for sale 10 pt Wolfe Racecraft cage, 16gal fuel cell, 90% of interior, just needs rear seat delete, rolls on stock suspension except tubular k & MM C&C plates $3500
46cougrrr is offline
post #2 of 24 (permalink) Old 10-17-2004, 12:21 AM
Fry Rice Specialist
Casper's Avatar
the half shaft are even the same length? hehe.....i can foresee some 31 spline 3.73 traclok pumpkin in the future....
CarDomain Page
Casper is offline
post #3 of 24 (permalink) Old 10-17-2004, 12:54 AM
AEDM8's Avatar
Wow, and those shafts look mean compared to the MN12's. Does the 03 pumpkin bolt in the same as our 8.8?
Hmmm.......
AEDM8 is offline
post #4 of 24 (permalink) Old 10-17-2004, 01:26 AM
Fry Rice Specialist
Casper's Avatar
i have a feeling that this thread will become a hot thread!!!
CarDomain Page
Casper is offline
post #5 of 24 (permalink) Old 10-17-2004, 05:21 AM Thread Starter
46cougrrr's Avatar
If we can use their halfshafts, we can use their upgraded aftermarket versions and, since I personally plan on swapping to mustang bolt pattern, i can swap to 31 spline. And the centersection is similar, but the mounting methods and mounting points are entirely different. But other than that, the gears and anything important relating to the differential is the same. Apparently the axles are the same in length, which I believe to be the most important part and the ends appear similar. As long as th axle shaft doesn't rub the rear upper control arm at full compression, everything should be splendid.
post #6 of 24 (permalink) Old 10-17-2004, 10:46 AM
I purchased a 2003 Cobra center section and it fits exactly the same as a Tbirds. I only had to change out the side gears and the pinion flange.
Mike Donley
Mike Donley is offline
post #7 of 24 (permalink) Old 10-17-2004, 01:33 PM Thread Starter
46cougrrr's Avatar
it mounts to the rear of the differential the same???? i could have sworn that the mounting method was different on the cover. The front's the same, that i knew, but i thought the rear was completely different.
post #8 of 24 (permalink) Old 10-17-2004, 06:59 PM
fast Ed's Avatar
Mounting is the same on the Cobra diffs., as our cars.
cheers,
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #9 of 24 (permalink) Old 10-17-2004, 07:14 PM
MaddMartigan's Avatar
Wouldn't that mean that the newer Explorer pumpkins would work too?
MaddMartigan is offline
post #10 of 24 (permalink) Old 10-17-2004, 07:49 PM
Chapter Director Coordinator
jamesD's Avatar
no, those mount really weird...
and according to the site, if the halfshafts are the same length, you don't need to swap bolt patterns, as they are 28 spline on the hub side! cool.. hmm.. ideas ...
jamesD is offline
post #11 of 24 (permalink) Old 10-17-2004, 08:53 PM
392Bird's Avatar
Acording to what I read, we could use the 03 Cobra pumpking and its half shafts by only switching the pinion flange. Is this how you guys understand it since the shafts are the same length, and 28 splines on the wheel end?
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #12 of 24 (permalink) Old 10-17-2004, 09:44 PM
Fry Rice Specialist
Casper's Avatar
i believe the answer is yes.
CarDomain Page
Casper is offline
post #13 of 24 (permalink) Old 10-18-2004, 01:05 AM
MarksM's Avatar
Send a message via AIM to MarksM
Look closely at the Half-shafts. You will notice that although the MN12 and Cobra may have the same length overall, the Cobra parts are shorter.
2007 Buell XB9S
MarksM is offline
post #14 of 24 (permalink) Old 10-18-2004, 02:23 AM
Refrigerator Raider Hater
GreenBird's Avatar
In the link he says he has to have the halfshafts cut to length, so apparently they are different enough so we can't use them.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #15 of 24 (permalink) Old 10-18-2004, 04:14 AM Thread Starter
46cougrrr's Avatar
yeah, but if you get aftermarket 03 halfshafts, it would be trivial to ask for a different length shaft compared to the innumerable things otherwise that could be different and would make use/modification difficult. length is an easy change.if that's all that's different, then a swap shouldn't be difficult.
post #16 of 24 (permalink) Old 10-25-2004, 11:53 PM
Fry Rice Specialist
Casper's Avatar
any update on this???
CarDomain Page
Casper is offline
post #17 of 24 (permalink) Old 10-26-2004, 12:45 AM
96bird's Avatar
This isn't new information. The cobra shafts are shorter by a little bit and can't be used. It would cost as much to modify a set of 03 cobra shafts (after you bought a set and modified them) as if you just got Raxles. You could also talk to GKN about making some HD shafts which they will do. I think Mike is running his 10.9s on the stock axles, so I don't think they are too bad of a piece. Even though he is running an automatic and that makes things a little easier instead of 5/6 speed.
Russell
96bird is offline
post #18 of 24 (permalink) Old 05-09-2005, 08:26 AM
Dead Link
kurzjunge is offline
post #19 of 24 (permalink) Old 07-10-2006, 05:18 PM
Anyone who has installed the frpp pumpkin with 3.73s and traction lok should know the pumpkins are identical to the cobras, because thats what the frpp catalog lists them under. And the half shafts will not work. Get in touch with The Driveshaft Shop-theyre on the web. They have stage II and V half shafts. I think thats what they call them, but they are very similar to their cobra upgrades.
teal944.6 is offline
post #20 of 24 (permalink) Old 11-08-2007, 11:53 AM
BlackbirdSport's Avatar
Send a message via AIM to BlackbirdSport
I have a set of cobra shafts and a set of SC shafts loose in the garage.
setting them right next to each other, the cobras are visibly shorter.
Also, with respct to "Ideas": Don't screw with yours. The only thing that the cobra has on us is the upper A arm being slightly stiffer. The MN12 and the IRS it has were developed at the same time, they were ment for eachother.
The cobra IRS is a hack. Ford required it to bolt into the car with no modification, to save cash. It's a good-as-it-gets IRS kit for a 79 Fairmont, be happy with your MN12.
"Keep making it thinner until it breaks, then go one size bigger."
My Cougar XR7
BlackbirdSport is offline
post #21 of 24 (permalink) Old 11-08-2007, 06:55 PM
mikemelancholic's Avatar
I was reading this thread from the beginning, thinking "This is old news." Then I saw the dates of the posts...
mikemelancholic is offline
post #22 of 24 (permalink) Old 05-30-2009, 08:12 AM
should this still be a sticky considering its current state of life, or lack thereof.
BigJohnny is offline
post #23 of 24 (permalink) Old 06-25-2009, 07:25 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
so 01+ cobra axles are 31 spline inboard, 28 spline outboard? If so, cool! They would only require a slight lengthening to work. Still good info.
-Rob
Rob is offline
post #24 of 24 (permalink) Old 06-25-2009, 09:01 AM
I think what's really missing is the R&D needed for this. I don't have a car torn apart to do this or the parts to try it. It does appear that if you wanted to use those half shafts you would just need to put in 31 spline side gears on your differential and to figure out a way to "shorten" your knuckles position in the car. Even then, I don't think anyone has done the homework to know if you even need to do that.
To that thinking, is the length of the outer splines the same or shorter than our stock half shafts or is it that the entire shaft length is shorter? If the shaft length is shorter then that should tell you what you have to adjust.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
