bushings - TCCoA Forums
post #1 of 12 (permalink) Old 03-16-2005, 11:26 PM Thread Starter
95thunderbird's Avatar
Send a message via MSN to 95thunderbird Send a message via Yahoo to 95thunderbird
bushings
Does anyone know where a guy could find a polyurithane bushing kit that is complete for every bushing in the suspension of the car, similar to an energy suspension kit for the mustang. My car is a 95 LX with a 4.6 V8. Any help would be greatly appreciated. thanks!
95thunderbird is offline
post #2 of 12 (permalink) Old 03-16-2005, 11:52 PM
MN12Performance.com would be your best bet. I think there is every bushing you need there.
whitecoug is offline
post #3 of 12 (permalink) Old 03-17-2005, 08:46 AM
Bradley Blaze's Avatar
Send a message via AIM to Bradley Blaze
yeah they have a kit that very affordable that includes everything you need
Bradley Blaze
I'd Love to Live Life in the Fast Lane, but I'm Married to a Speed Bump
Bradley Blaze is offline
post #4 of 12 (permalink) Old 03-21-2005, 03:02 PM
I have my front and rear set sitting and I was wondering how hard is it to install? i'm still a novice mechanic and am learning as I go. Is it something I can do or should I bribe some other car guys with beer to help me?
Grims95SC is offline
post #5 of 12 (permalink) Old 03-21-2005, 03:07 PM
About 1/2 the bushings in the front require a press to put them in. Almost all of the rear bushings do.
Rich95XR7 is offline
post #6 of 12 (permalink) Old 03-21-2005, 03:11 PM
Nuts... In the instructions that came with it, it looked like all that was used to pop 'em in and out was a 3 jaw pulley puller. So no chance I can do it then eh? DAMN!
post #7 of 12 (permalink) Old 03-21-2005, 03:17 PM
96bird's Avatar
If the instructions say you can then you probably can....I have installed some poly stuff with just a 2 or 3 jaw puller and it worked pretty well. I don't know about installing the whole MN-12 performance kit though.
Russ
96bird is offline
post #8 of 12 (permalink) Old 03-21-2005, 03:24 PM
Even if I could do a good chunk of it with the tools I have it would be nice, save big $.
Since you've done it 96bird, how hard would you say it is?
post #9 of 12 (permalink) Old 03-21-2005, 03:34 PM
96bird's Avatar
No I have only done a few of the bushings.....Like the rear knuckle kit....and it wasn't too bad at all. I think 94DailyDriven4.6 did it himself....so you may want to ask him.
Russell
96bird is offline
post #10 of 12 (permalink) Old 03-21-2005, 03:46 PM
Cool thanks for the heads up!
post #11 of 12 (permalink) Old 03-21-2005, 11:15 PM
I've got a press, so I've never thought about doing it with anything else. I guess it's possible, but I wouldn't want to do it.
post #12 of 12 (permalink) Old 03-22-2005, 06:56 AM
One thing about the front lower bushings...
The bushing I got from Rich didn't quite fit into it's spot. The guy at the machine shop had to bore out my control arm a slight bit to get the bushing pressed in...and it was still difficult.
That's just what happened to me. I am now a believer in just buying the whole control arm or whatever instead of just changing bushings. Makes things much easier.
Grasshopper is offline
