Tips to install Springs and shocks/struts.. - TCCoA Forums
post #1 of 24 (permalink) Old 03-21-2005, 10:34 AM Thread Starter
Anything I should look out for when I install my lowering springs and shock/strut combo? Any normal bolts that break that I should get before install? Idea on how long it will take? Thanks! oh yea and what speical tools
BTW - Vogtlang 1.6 drop and Tokio shock/struts will be going in...
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #2 of 24 (permalink) Old 03-21-2005, 11:20 AM
go get yourself a set of the bottom front shock bolts. i had to use a air hammer to get mine out. the backs took me about 1h. just stick and move. i had to have the part store swap my springs cuz the spring compressor i had wouldnt fit in the springs right. i hope that helps some.
2007 mazda 5- grocery getter
95 mustang gt convertible- newest project
thunderchicken17 is offline
post #3 of 24 (permalink) Old 03-21-2005, 12:34 PM
If you want to make it really easy, but a set of new front shock mounts, have the front spring/shock combo assembled ahead of time, so all you have to do is bolt the new assembly in. That alone will save you hours.
Rich95XR7 is offline
post #4 of 24 (permalink) Old 03-21-2005, 12:50 PM
94t-birdlx's Avatar
Send a message via AIM to 94t-birdlx Send a message via MSN to 94t-birdlx
That is the way I did mine, helped out a lot. Also rear spring isolators, possibly the lower shock bolts in the front.
"Technical skill is mastery of complexity while creativity is mastery of simplicity."
94t-birdlx is offline
post #5 of 24 (permalink) Old 03-21-2005, 02:06 PM Thread Starter
so I need front shock mount, front shock bolts and rear isolators then?
2004 F150
KrAzyT is offline
post #6 of 24 (permalink) Old 03-21-2005, 03:34 PM
94t-birdlx's Avatar
You don't absolutely need them but you won't know to you start ripping things apart. If you want to be on the safe side then you should get those things, or you can wait til you start and go from there. I went with new Isolators to get the poly ones, new front shock mounts so I didn't need to dismantle my old shocks/coils, and my lower shock bolt was in good condition so I re-used it.
post #7 of 24 (permalink) Old 03-22-2005, 12:13 PM Thread Starter
think i forgot a few tools..
2004 F150
KrAzyT is offline
post #8 of 24 (permalink) Old 03-22-2005, 03:32 PM
make sure you get the rear fairly high off the ground on stands.
you will have to put your foot on the RLCA to get the srping out....you'll need the travel space to push it down that far.
the writeup on MN12 performance is the tech article i used and had all the info i needed. make sure you torque everything back per the specs.
a great DIY mod even for the beginners.
1994 Thunderbird - Renegade Racing Long block, TFHS Trans, NA/SVO intake. Cam94 lives!
2010 Shelby GT500 - Black/Silver
1995 Thunderbird LX - 2000 GT PI Swap by W&S Motorsports - Sold on Tccoa.
Bill H is offline
post #9 of 24 (permalink) Old 03-22-2005, 07:03 PM Thread Starter
I got the one side done.. well the front left I know what to do now. the rest should be cake
2004 F150
KrAzyT is offline
post #10 of 24 (permalink) Old 03-22-2005, 07:16 PM
JustinH's Avatar
get a good life insurance policy if you are compressing/decompressing the front spring/shock assembly with one of those hand compressor deals.
JH
JustinH is offline
post #11 of 24 (permalink) Old 03-22-2005, 07:23 PM
94t-birdlx's Avatar
JH
I second that! I did the front struts on my New Yorker and I those were big. I took out the coil/shock combo, looked at it and said "I need to go to the parts store". I got new shock mounts and put the new stuff together. The old ones are still together in my garage.
post #12 of 24 (permalink) Old 03-23-2005, 07:02 AM Thread Starter
Almost got the right side removed minus the damn upper spindle bolt. Damn thing wont come out. ne tips?
2004 F150
KrAzyT is offline
post #13 of 24 (permalink) Old 03-23-2005, 07:09 AM
94t-birdlx's Avatar
Put the nut back on and hit it with a hammer.
post #14 of 24 (permalink) Old 03-23-2005, 07:18 AM Thread Starter
ooooo I got it I love da hamma
2004 F150
KrAzyT is offline
post #15 of 24 (permalink) Old 03-23-2005, 10:46 AM
i had to use a air hammer on my car
post #16 of 24 (permalink) Old 03-23-2005, 07:39 PM
So..
Shock mounts, front shock bolts, and rear spring isolators eh???
Can Dan N. hook me up with these parts? (Motorcraft will be fine I am assuming right?)
Good thread... I plan to have someone else do the install I think.
1997T-Bird is offline
post #17 of 24 (permalink) Old 03-23-2005, 08:12 PM Thread Starter
everything was in good condition.. basically since the car has never seen salt nor rarely a .01 inche of snow. it was very easy actually... just have a hammer ready!
2004 F150
KrAzyT is offline
post #18 of 24 (permalink) Old 03-23-2005, 08:15 PM
94t-birdlx's Avatar
Its really not that hard at all, the worst being if you want to take the fronts apart.
post #19 of 24 (permalink) Old 03-24-2005, 05:47 PM Thread Starter
problem! rear wont go back up... like the axle came out or somthing and it wont slide into the pumpkin so I can rebolt the top part (cant recall name)
2004 F150
KrAzyT is offline
post #20 of 24 (permalink) Old 03-24-2005, 05:48 PM
did u try to jack the arm up?
post #21 of 24 (permalink) Old 03-24-2005, 05:51 PM Thread Starter
yeah all the way.. is it somthing with the axle?
2004 F150
KrAzyT is offline
post #22 of 24 (permalink) Old 03-24-2005, 11:09 PM
94t-birdlx's Avatar
Did you remove the axle? Try turning the axle a bit to slide it in.
post #23 of 24 (permalink) Old 03-25-2005, 12:04 AM Thread Starter
nevermind I got it done today
2004 F150
KrAzyT is offline
post #24 of 24 (permalink) Old 03-25-2005, 12:04 AM Thread Starter
It does clunk a little.. but im sure i just need to tighten the top shock/strut nuts.. oh well yay its all coo looking now
2004 F150
KrAzyT is offline
