do strut rod bushings come in pairs? - TCCoA Forums
post #1 of 15 (permalink) Old 03-27-2005, 09:48 AM Thread Starter
Hi,
Do the strut rod bushings (MOOG K8680 and K8659) come in pairs? (i.e. do I need to order 1 or 2 of each to do the whole car?). They are $20.79 and $36.79, respectively, from Rock auto.
I read a ton of old posts on this and it seems that most of the posters had bad LCA to strut rod bushings. Has anyone had the OEM strut rod to K-member bushings fail? (I know about the MOOG failures)
Lastly, has anyone ever found out if the LCA's for the Mark VIII are the same as the T-Bird? The T-Bird ones are 1/2 the price. Any concensus on this?
Calvin
97 Mark VIII LSC
03 Navigator Ultimate
calviroman is offline
post #2 of 15 (permalink) Old 03-27-2005, 10:04 AM
Well when you buy them from ford you get in one package 2 fronts of the LCA and you need to buy the rears too they also come in a pair. So when you buy them you have to order one set for the front and one for the back and it will take care of the 2 strut rod ends that go through the LCA. As for the moog ones i really dont know
MattsLE97 is offline
post #3 of 15 (permalink) Old 03-27-2005, 01:58 PM Thread Starter
Thanks Matt,
Does anyone know about the MOOG's from Rock Auto. I just want to be sure before I order that I'm getting the correct stuff.
post #4 of 15 (permalink) Old 03-27-2005, 02:05 PM
JR Tigerstar's Avatar
JR Tigerstar is offline
post #5 of 15 (permalink) Old 03-27-2005, 02:11 PM
Full Metal
RedThunder94's Avatar
IIRC, i think the difference in price is because of the material they are constucted of, the mark's control arms, i believe are aluminum, the thunderbird's is not.
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #6 of 15 (permalink) Old 03-27-2005, 02:59 PM Thread Starter
Yes, the part numbers are MOOG K8680 and K8659.
post #7 of 15 (permalink) Old 03-27-2005, 03:16 PM
post #8 of 15 (permalink) Old 03-27-2005, 04:34 PM
Chapter Director Coordinator
jamesD's Avatar
the moog strut rod to frame bushings are a whole kit for the front
i bought TRW strut rod to LCA individually.. so i don't know there, but i think thats a set as well
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #9 of 15 (permalink) Old 03-29-2005, 09:13 AM
Overkill Fetish Freak
Do not get the Moog Strut rod bushings because they suck....
Dr. FrankenCougie is offline
post #10 of 15 (permalink) Old 03-29-2005, 10:32 AM
jamesD's Avatar
well.. i did.. but i used the stock "washers" instead of the small **** they give you..
jamesD is offline
post #11 of 15 (permalink) Old 03-30-2005, 09:47 PM Thread Starter
I thought these failures were attributed to using the 3" long sleeve -vs- the 2.75" version???
post #12 of 15 (permalink) Old 03-31-2005, 07:12 AM
"I thought these failures were attributed to using the 3" long sleeve -vs- the 2.75" version???"
Even with the "fix" they only lasted 2 months at best on Cougie. I do take the car to the extremes in the mountain turns so take that into consideration.
post #13 of 15 (permalink) Old 03-31-2005, 08:53 AM
wilson502's Avatar
seems better off just getting oem ones
2007 White Ford Focus SE ZX3 Hatchback (The new driver)
1997 Alpine Green 4.6L Bird (SOLD!)
Mods:
Removed Air silencer, Clear Corners, Silverstar headlights and corner lights, Moroso Bluemax Spiral Core wires, Custom 3" Magnaflow exhaust with 2.5" Y-Pipe, 300-450 HP J-mod Kit by dirtyd0g , Hayden 30k GVWR Trans Cooler, Sport Front Suspension, 03-04 Cobra Rear Shocks, PBR Front Brake Swap, Xcal 2 by Lonnie @ Blueovalchips.com, 22C plugs, 180F T-stat, 02GT MAF/Airbox with K&N Drop in, Griffin Radiator, Cobra Water Pump
wilson502 is offline
post #14 of 15 (permalink) Old 03-31-2005, 09:21 AM
The Great Obucina's Avatar
read further into it....the ones that are failing are on the driver side right under both power steering and transmission fluid lines, how do i know this? 2 bushings blew out in under 6 months. Its the thermoplastic that is a problem.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #15 of 15 (permalink) Old 03-31-2005, 08:30 PM Thread Starter
So I guess the key is to insure that the bushings stay free of oil based products?
