Drifting left and right? - TCCoA Forums
post #1 of 6 (permalink) Old 04-07-2005, 07:56 AM Thread Starter
At highway speeds my car jerks and drifts left to right. It also does this when i brake moderately. I've looked at all my front suspension components and they all look in good shape. And i just had an alignment recently. Does this sound like something in my rack and pinion maybe? Also, i didn't know you couldn't get UCA's or LCA's at autozone??? Because i was gunna get some, but he said they don't carry them?? I figure that while i'm under there for the tokico's and the poly's, i'd try to pinpoint this problem and fix it. But does anyone have suggestions as to what it might be?
Adam B.
Adam B. is offline
post #2 of 6 (permalink) Old 04-07-2005, 09:16 AM
Mark M. TCCoA VP's Avatar
Check your rear sway bar.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #3 of 6 (permalink) Old 04-07-2005, 09:30 AM Thread Starter
Would that cause drifting left and right at highway speeds? maybe a bad bushing or something?
Adam B. is offline
post #4 of 6 (permalink) Old 04-07-2005, 10:57 AM
Well they should be available
Left hand upper = Moog # K8596
Left hand lower = Moog # k80053
Right hand Upper = Moog # K8598
Right hand lower = Moog # k80055
I agree with the sway bar bushings..
The other thing to look at is your strut rod bushings in the front.
If they are loose the car will tend to follow the road and sway.
jbird6r is offline
post #5 of 6 (permalink) Old 04-07-2005, 11:14 AM
rustyul's Avatar
Bad ball joints would certainly cause that problem. Extremely worn tie rod ends would also cause that, but they should have told you that they were worn when you had a front end alignment. The front end can't be aligned properly with worn ball joints or tie rod ends...
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #6 of 6 (permalink) Old 04-07-2005, 02:08 PM Thread Starter
Just a thought, could a bad tire cause this problem? Because i've hit quite a few potholes up here in columbus with my 18's. And i think i'm gunna call BS on autozone for telling me that they didn't carry the UCA's or LCA's. I looked it up on their website.
Adam B. is offline
