slight ball joint issue - TCCoA Forums
post #1 of 10 (permalink) Old 04-25-2005, 04:06 PM Thread Starter
Ok so my lower ball joint has just desided it was time to fail, so to make a long story short, my car in a parking lot in a place where tow trucks can't take it to get it repaired. So i will have to do this in a parking lot....
so other than a new lower ball joint what would i need to replace the thing without risking life and limb?
::sigh:: I have to fix it by may 3rd during finals week :-(
pennsyfan is offline
post #2 of 10 (permalink) Old 04-25-2005, 04:14 PM
Rolling-Thunder's Avatar
You will need the entire lower control arm, which comes with a new ball joint and new bushings. To replace just the lower ball joint, you would have to press out the old one, and press in the new one.
The lower shock bolt can be a pain, so read up on old posts about that.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #3 of 10 (permalink) Old 04-25-2005, 06:12 PM Thread Starter
"To replace just the lower ball joint, you would have to press out the old one, and press in the new one."
my dad bought a new ball joint and rented a press, thanks for the tips though
post #4 of 10 (permalink) Old 04-25-2005, 06:32 PM
jk69cat's Avatar
trust us, your better off with a new arm
mn12 less!
jk69cat is offline
post #5 of 10 (permalink) Old 04-25-2005, 07:12 PM
Keep this in mind;
1. You will have to remove the lower control arm to replace the ball joint.
2. You cannot buy the lower control arm to frame bushings separately, they are only sold with a new control arm, which comes with a new ball joint installed.
3. Dollar wise, since you already have the press, you will be saving money there, but losing the chance to replace the bushings.
post #6 of 10 (permalink) Old 04-25-2005, 07:21 PM
JustinH's Avatar
Steve is right on. Anyone who screws with the press is just wasting their time/money.
JustinH is offline
post #7 of 10 (permalink) Old 05-18-2005, 06:53 PM
Kaptn' Obvious's Avatar
Send a message via AIM to Kaptn' Obvious Send a message via Yahoo to Kaptn' Obvious
Originally Posted by Rolling-Thunder
Keep this in mind;
I believe you're referring to the control arm to K member bushings. I bought a set of MOOG bushings from O'reiley (or howevur u spel it) It was one of those "mission critical weekends and I couldn't find the whole arm anywhere. I pressed them in along w/ new ball joints.
I agree, buy the whole arm if you can...
Mostly stock...
For now...
Kaptn' Obvious is offline
post #8 of 10 (permalink) Old 05-18-2005, 07:14 PM
You might wanna look at the date of the last post He probably already fixed it
4-25-05
MattsLE97 is offline
post #9 of 10 (permalink) Old 05-19-2005, 03:20 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
welcome to my world. I happened upon a situation like yours, but I was stuck in a parking lot with 1" of water when it was 32*F outside. My lower shock bolt was siezed into the lower control arm, and I broke 2 dang sockets. It was a great day.
Thomas is offline
post #10 of 10 (permalink) Old 05-19-2005, 10:31 AM Thread Starter
Thanks for the info that y'all gave me, I had no air tools so fixing the ball joints in a parking lot was a lost casue, so we got it towed.
"welcome to my world. I happened upon a situation like yours, but I was stuck in a parking lot with 1" of water when it was 32*F outside. My lower shock bolt was siezed into the lower control arm, and I broke 2 dang sockets. It was a great day."
That really sounds like it would be bad. I managed to go through 3 tow trunk companies until i found one that could help me out
