Whole wheel moves freely.... ??? - TCCoA Forums
post #1 of 4 (permalink) Old 04-26-2005, 10:19 AM Thread Starter
The Band, not the Disease!
AnthraxBird's Avatar
I was testing my front suspension out yesterday, and I noticed this: When in reverse and moving slowly, when I hit the brakes the 2 front wheels shifted towards the front of the car, when I let go of the brakes they returned to normal. It wasn't a huge shift, maybe an inch or two. What do you guys think, LCA?? I'm about to install new strut rod bushings, UCA's and LCA's, and new tie-rod ends. Anyone?
AnthraxBird is offline
post #2 of 4 (permalink) Old 04-26-2005, 10:32 AM
Front to Rear movement is normally a result of failed strut arm bushings.
You should NOT drive the car until that is fixed. Radical changes in steering geometry
can result in you finding yourself in another lane of traffic!
tbirdbrain is offline
post #3 of 4 (permalink) Old 04-26-2005, 10:47 AM
Originally Posted by AnthraxBird
...It wasn't a huge shift, maybe an inch or two...
Ok, those words should never be used together when describing a worn suspension!!!
I agree strut arm bushings. Replace them!!
69 F100 LWB w/460 Engine
post #4 of 4 (permalink) Old 04-26-2005, 10:58 AM Thread Starter
They look ratty as all hell. It's total garbage. I bought the kit from autozone, it has a couple metal tubes, bushings, etc. Doesn't look like all those parts would fit... it has to be different looking when I get it apart. I've got a ton of work to do!!! UCA, LCA's, tie rod ends, rod bushings, 180 tstat, colder plugs, wires, chip. Im gonna be up allllll night!!! Thanks guys.
