isolator bushings - TCCoA Forums
post #1 of 2 (permalink) Old 05-15-2005, 06:16 PM Thread Starter
isolator bushings
i have recently pulled out my complete irs suspension in the back and while its out i will be changing gears and putting in new bushings and making it like new,but i was wondering how to get the subframe isolator bushings out becuase i want to replace those too.they look like they are pressed in,is there a special tool needed to get them out.if anyone has changed these whats the easiest way to get them out. thanks
IBEMERCUN is offline
post #2 of 2 (permalink) Old 05-16-2005, 02:13 PM
girdnerg's Avatar
Maybe this will help. It's from mn12performance.com.
Clicky
Hope that helps,
Rob
girdnerg is offline
