Power steering hose removal? - TCCoA Forums
post #1 of 2 (permalink) Old 05-16-2005, 11:24 AM Thread Starter
Jack of all trades, Master of none
bobbylx's Avatar
Ok, so I have to replace the high pressure metal hose that runs from the power steering pump to the passenger side of the rack. On the rack it's easy, just a threaded fitting, but how do I get to it on the pump? It's hidden up in there so I can't even see it. Also, anyone know the part # to this at Autozone? I found one that sounds right but haven't driven up there to look at it. Is this it?
POWER STEERING HOSE for a
1995 FORD THUNDERBIRD
PRESSURE HOSE (Change)
POWERCRAFT 91836 $29.99
Deaf and blind and dumb and born to follow
what you need is someone strong to guide you
bobbylx is offline
post #2 of 2 (permalink) Old 05-16-2005, 11:35 AM
Overkill Fetish Freak
It's in there pretty good and not a fun job to replace. To make it eaiser you could drop the pump but that can be a PITA as well.
-Scott
Dr. FrankenCougie is offline
