help!!!!!!!!!! - TCCoA Forums
post #1 of 2 (permalink) Old 05-23-2005, 02:39 AM Thread Starter
Chknhawk97's Avatar
help!!!!!!!!!!
Okay, I have to replace the lca, should be a quick and easy job right? Well, I am stuck in Germany and I have a very limited supply of tools and parts. So to get to the point, I have unbolted everything from the lca, but I have one bolt that just doesn't want to come out. I know that you guys have had this problem before, but I need to know an easy way to get that bolt out that connects the strut to the lca. Thanks. And yes, I am still searching the thread for an answer.
Chknhawk97 is offline
post #2 of 2 (permalink) Old 05-29-2005, 05:45 AM Thread Starter
Chknhawk97's Avatar
Talking
okay well problem solved, I just got mad and ordered a whole new front suspension. So I have come to the conclusion that it is just easier to spend the money on new springs, struts, lca, uca, sway bar kit, and urethane bussings for both sides than to try to screw around with that annoying lower mounting bolt. After all you can't take the money with you right.
