Put lowering springs on only dropped 1/2inch in front??? - TCCoA Forums
post #1 of 3 (permalink) Old 06-04-2005, 09:03 PM Thread Starter
low5.0's Avatar
Put some intrax springs on my car and it slammed it in the back and dropped it like a half inch maybe in the front. The kit said 2inch drop all the way around. Is something in the front end possibly limmiting it or did i just get ripped on springs. Its a 93 5.0lx any help would be greatly apreciated
natedawg the blackest
FRP 3.73 gears
off road h-pipe -
true dualw/flowmasters
75mm mass air meter
custom chrome intake
lentech valve body
low5.0 is offline
post #2 of 3 (permalink) Old 06-05-2005, 04:50 PM
Teal94BirdV8's Avatar
Send a message via AIM to Teal94BirdV8 Send a message via Yahoo to Teal94BirdV8
I know the intrax dropped my bird pretty low. I rememer hearing somewhere that if you lower your mn12, it will hit some sort of filter (or something?)..
Also, you're springs still need time to settle..
94 LX V8 & 93 SC gone. Not forgotten.
1992 Lincoln Mark VII LSC Cobra U/L intake, PP 65mm TB, Powerdyne BD-11 8#, Walbro 255, FRPP 30lb Injectors, MSD ignition, 3.8 Taurus E-fan, A9P MAF conversion, Pypes 1&5/8" Shortys, O/R H-Pipe, 4.10 Trac-Lok, T-5 swap, FRPP flywheel, Ram HDX clutch, Steeda Clutch kit
2002 F150 FX4 Lariat 6" Fabtech, 3" BL, Stock FX4 wheels, 37x12.50 Nitto Trails, Yukon 4.56s, Detroit TrueTrac, Edge Evo, 8K HIDs, PowerStop truck&tow kit
1996 GMC Suburban SLT 6K HIDs, crystal clear light set, daily beater @ 222k miles
Teal94BirdV8 is offline
post #3 of 3 (permalink) Old 06-05-2005, 08:07 PM
If the springs weren't lined up correctly on the strut bodies and upper mounts when they were installed onto the struts, it would have an effect on ride height. If that is the problem, they will probably settle into place.
-Rod
