ahhhhh more squeaking - TCCoA Forums
post #1 of 9 (permalink) Old 07-05-2005, 09:08 PM Thread Starter
i keep hearing this really annoying squeak from the drivers side wheel area. It is like ughhhh squeak squeak squeak squeak. When it first started it was barely noticeable but it gets worse and worse everyday. Any ideas on what it is and how to fix it.
thx
post #2 of 9 (permalink) Old 07-08-2005, 12:12 AM Thread Starter
ahhhh come on anyone. This squeaking is killing me, first off it is embarassing and second it is very annoying.
post #3 of 9 (permalink) Old 07-08-2005, 12:39 AM
Refrigerator Raider Hater
GreenBird's Avatar
When does it happen? when you go over a bump? when you turn left?
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 9 (permalink) Old 07-08-2005, 10:08 AM Thread Starter
it happens at all times when the car is in motion. It sounds like its something to do with the wheel or brake rotor or something.
post #5 of 9 (permalink) Old 07-08-2005, 02:53 PM
I know you said it happens all the time in motion but does it imedietly happen when you first start to drive it or does it start after a mile or 2?? If so its probably the brake rotors and pads. If it happens no matter what then i think it could possibly be a wheel bearing starting to fail
MattsLE97 is offline
post #6 of 9 (permalink) Old 07-08-2005, 09:52 PM Thread Starter
yea i think it only happens after i have drivin a few miles.
post #7 of 9 (permalink) Old 07-11-2005, 01:09 AM
I had a problem like and I finally realized that my brake shield (sorry not sure what to call it) was rubbing on the rotor. This is the thin aluminum plate on the back of the rotor that is attached to the spindle. They are easy to bend. And if your rotors are warped like mine were, then you get a periodic grinding/hissing noise.
Perch
perch is offline
post #8 of 9 (permalink) Old 07-12-2005, 12:00 PM Thread Starter
it has now turned into a ticking noise and is not as loud but still annoying
post #9 of 9 (permalink) Old 07-12-2005, 02:57 PM
4 Cam Bird's Avatar
My car makes that noise too. from the left fron even. The ticking sound that is. I don't have any idea what it is. I replaced all the suspension last year so nothing is just worn out. I inspected everything real good and didn't see anything askew. I agree, that it is an annoying sound. But I am pretty sure it isn't anything to worry about. Be sure to post up though if you figure out how to get rid of it.
2011 CTS-V Wagon
4 Cam Bird is offline
