Anyone w/ Eibachs have clearance problems at K-member? - TCCoA Forums
post #1 of 14 (permalink) Old 07-06-2005, 12:54 PM Thread Starter
gecko2424's Avatar
My K member has about 3" of ground clearance. I'm running 245/40/18's too. I'm going to add a spacer in the springs, any other ideas?
SOLD!!!!
5.4 block from 99 expedition bored .20 over
Forged crank/Manley Rods/JE flat tops/chromemoly rings and Steeda Underdrives
P&P PI heads (by me) w/ 3 angle valve job w/copper gaskets with ARP studs/bolts and One piece lightning cams
80mm Pro-M MAF and Cut & welded '95 4.6 intake
Jmodded Trans & Trac-loc pumpkin (Cobra) 3.27
Raxles, ADDCO 1 1/4", Eibachs, JL Braces
18" CEC type 169 wheels w/ 245/40 front 255/45 rear
gecko2424 is offline
post #2 of 14 (permalink) Old 07-06-2005, 01:04 PM
Stock 225/60/16 = 26.7" Diameter
Your 245/40/18 = 25.7" Diameter
So just your tire size lowers the car 1/2" or more.
I have Eibach's but am running 245/50/17 (26.8") and I don't have any (major) ground clearances. I just have to be careful how closely I pull up to a parking stop "thingy".
Here's what my 245/50/17, 17 x 8.5 wheel, Eibach spring, setup looks like:
69 F100 LWB w/460 Engine
post #3 of 14 (permalink) Old 07-06-2005, 02:29 PM
95greenbird's Avatar
I normally don't have any issues with the k-member but if I don't take speed bumps VVVVEEEERRRRYYYY SSSSLLLLOOOOWWWW, it will hit the underside of the body right behind the wheel wells on top of the bump. I'm running 235/60-15 tires.
Edit: One other thing, I can't fit my floor jack under the k-member without driving the car up on two 2x10s first.
Kevin
Mid-Atlantic Drag Racing Team. 15.589 @ 88.64 mph
MAMN12.COM
Get all your Ford parts from Dan Newman
Green 95 4.6L Thunderbird LX
*J-Modded 00 Mustang GT Transmission and torque converter*
*Mark VIII Flexplate*
*K&N*
*Eibach Springs*
*Hayden Transmission cooler*
*3.27 Trac-loc*
*Removed air silencer*
*Swapped Climate Control and Radio Locations*
*MARCH underdrive pulleys--soon to come*
95greenbird is offline
post #4 of 14 (permalink) Old 07-06-2005, 02:29 PM
I've got Eibach's with Koni shocks...
And with my 245/45/18 I haven't got a slightest problem..
Other than getting the jack under the car..
But the clearance for the Kmember doesn't matter that much
unless you're driving on really bad roads with stuff passing
between the wheel... Or a stone in the middle of the road....
//Per
Thyg0d is offline
post #5 of 14 (permalink) Old 07-06-2005, 04:53 PM Thread Starter
gecko2424's Avatar
Stone happened saturday. Any center ridge in the road, where it dips where most cars tires go, I shave those off every time. Luky to only have a scratch on the oil pan
What tires do you have?
SOLD!!!!
post #6 of 14 (permalink) Old 07-06-2005, 04:57 PM
Teal94BirdV8's Avatar
Send a message via AIM to Teal94BirdV8 Send a message via Yahoo to Teal94BirdV8
hm. I've never had a clearence problem, with my 2+ Intrax drop. I can even clear a cement parking log.
Oh yeah, I cant fit a jack under my car (well..on the sides) withough driving up on some boards.
94 LX V8 & 93 SC gone. Not forgotten.
1992 Lincoln Mark VII LSC Cobra U/L intake, PP 65mm TB, Powerdyne BD-11 8#, Walbro 255, FRPP 30lb Injectors, MSD ignition, 3.8 Taurus E-fan, A9P MAF conversion, Pypes 1&5/8" Shortys, O/R H-Pipe, 4.10 Trac-Lok, T-5 swap, FRPP flywheel, Ram HDX clutch, Steeda Clutch kit
2002 F150 FX4 Lariat 6" Fabtech, 3" BL, Stock FX4 wheels, 37x12.50 Nitto Trails, Yukon 4.56s, Detroit TrueTrac, Edge Evo, 8K HIDs, PowerStop truck&tow kit
1996 GMC Suburban SLT 6K HIDs, crystal clear light set, daily beater @ 222k miles
Teal94BirdV8 is offline
post #7 of 14 (permalink) Old 07-07-2005, 02:00 AM
Ouch.... Not good..
I've got 245/45/18 in front and 275/40/18 back all Nitto NT555's
from Cudaz101...
//Per
Thyg0d is offline
post #8 of 14 (permalink) Old 07-07-2005, 11:48 AM
crash's Avatar
I've got Eibach lowering springs with Koni's on stock 225/60-16 tires. I can just barely get my floor jack under my car.
Chris
1998 Toreador Red Mark VIII LSC
crash is offline
post #9 of 14 (permalink) Old 07-07-2005, 12:53 PM
392Bird's Avatar
I made some ramp stops for mine, so I can park it on ramps in the garage. I park it this way all the time in the front so I can do minor stuff to it with out having to try to get a jack under it. Makes it very easy to work above or below the engine.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #10 of 14 (permalink) Old 07-07-2005, 03:46 PM
Wow...
I want a garage like that!
My fathers garage is so narrow I almost have to climb out
thru the window... And no... I'm not that fat...
//Per
Thyg0d is offline
post #11 of 14 (permalink) Old 07-07-2005, 03:52 PM Thread Starter
gecko2424's Avatar
3 car garage and 20x30 barn...and I still park outside. Figure that out.
I've got nitto 555's up front and taller/wider sumitomo's in rear, very sticky. I didn't know they made a 245/45/18, I'll have to check it out.
SOLD!!!!
post #12 of 14 (permalink) Old 07-07-2005, 05:08 PM
terraplane8's Avatar
Eibachs's and 235/60/16's, no clearance issues, other than the flowmaster exhaust's flange connector by the differential.
Submariners do it deeper...
terraplane8 is offline
post #13 of 14 (permalink) Old 07-07-2005, 05:27 PM
That's easy.. You've got to much sh!t stuffed in that garage..
And you should be jailed for it!
Got the tires from Cudaz101 (Brad)here..
//Per
Thyg0d is offline
post #14 of 14 (permalink) Old 07-07-2005, 07:00 PM
Whining Intakes Rock
Al_Florida's Avatar
Eibach's on 16's no clearance problems.
# 0 rows returned
# drop table users;_
Al_Florida is offline
