KYB GR2 vs. Monroe Reflex?? - TCCoA Forums
post #1 of 11 (permalink) Old 07-15-2005, 02:55 PM Thread Starter
These will cost me the same, about $5 apart from one another. Which is a better shock for someone that does a lot of both city and highway driving, but occasionally likes the backroad aggressive driving. Longevity is important as well.
BTW, currently on stock springs, but if I ever find a set of SC, or lower springs, they would be on the car.
post #2 of 11 (permalink) Old 07-15-2005, 03:13 PM
Both are relatively cheap shocks. I've used the KYB GR2's on a few of my MN12's now, and I can at least say that they're worth the money.
I don't have any experience with the Monroe's.
-Rod
post #3 of 11 (permalink) Old 07-15-2005, 03:32 PM
Eleventeenth Gear Poster
Aaron K.'s Avatar
I thought the Monroe Reflex was discontinued for the MN12?
Aaron K. is offline
post #4 of 11 (permalink) Old 07-18-2005, 10:09 PM Thread Starter
Its still available, well at the local advance anyway. So is there anything else I should look into for my needs.
post #5 of 11 (permalink) Old 07-19-2005, 12:43 PM
JoeyICU's Avatar
sell ya my Sport springs when i get to lowering my car?
JoeyICU is offline
post #6 of 11 (permalink) Old 07-21-2005, 06:25 PM
-Rod
Just put GR2's on my 95 Mark p/n 344110. The sleeve on the bottom leaves a 1/2 inch space on both sides of the rubber bushing, is that right? Did I get the wrong shock, & if so, should I exchange them or add spacers? At this point there is absoluty nothing pressing on the sides of the bushing. Info needed asap, if possible. Thanks, Ed
big ed is offline
post #7 of 11 (permalink) Old 07-21-2005, 08:12 PM
Ed, I'm not really sure what you're talking about. Could you post a pic?
The shock shouldn't be able to move around on the bolt that attaches it to the lower control arm. If it can, then you need a spacer in there.
-Rod
post #8 of 11 (permalink) Old 07-21-2005, 09:25 PM
Will try & post Friday. The bushing on the bottom has a metal sleeve going through it, for the bolt, that sticks out 1/2 inch on either side of the bushing. I have not seen this before. But the sleeve hits the washer between it & the control arm on one side & the head of the bolt, with built in washer, on the other. Like an upside down "T", with nothing pressing against the bushing at the bottom of the shock. I've emailed KYB & will call them in the morning. My guess is that at least some arrangement of spacers is required. But if I have the wrong shocks at least it is a quick job to change. Niether the shock or the bushing will move right now but with no compression on the bushing I am concerened that over time the bushing will give way to one or both sides, i.e. get sloppy. Ed
big ed is offline
post #9 of 11 (permalink) Old 07-21-2005, 09:48 PM
Ed,
It sounds like it is set up correctly. I'd post up a pic of the KYB's on one of my cars, but the member pages are all screwed up right now.
-Rod
post #10 of 11 (permalink) Old 07-22-2005, 10:46 AM Thread Starter
So the GR2's would be better for me??? What is this I hear of Cobra shocks on the rear??
post #11 of 11 (permalink) Old 07-22-2005, 01:47 PM
Shocks on, struts should be on next week, will let you know my KYB experience then. Shocks feel very good. I have heard that Cobras shocks are very stiff, I do not personally know. After all what is stiff to one person may not be to another. Ed
big ed is offline
