Clunking from???? - TCCoA Forums
post #1 of 3 (permalink) Old 07-17-2005, 12:42 PM Thread Starter
MN1293-232's Avatar
Clunking from????
When I shift my car into gear or when the car shifts when accelerating i get a single clunk noise. The problem is this only happens like once a week if that so its hard to find the problem. The trans mounts look good, axle mounts look good, other than that the only thing i could say would be a u-joint. So Iam leaning to the axle mounts or u-joint cause thats where the sound seems to come from. any suggestions??
MN1293-232 is offline
post #2 of 3 (permalink) Old 07-17-2005, 02:17 PM
It is likely one of these that is causing the "clunk":
engine mounts
trans mount
trans crossmember mounts
U-joints
Centersection mounts (diff bushings)
Centersection cover mount (diff cover mount)
-Rod
post #3 of 3 (permalink) Old 07-17-2005, 02:34 PM Thread Starter
MN1293-232's Avatar
Yeah thanks. Looks like I overlooked quite a bit
