Lower control arms? - TCCoA Forums
post #1 of 4 (permalink) Old 07-18-2005, 07:22 AM Thread Starter
Lower control arms?
I want to change my lower control arms. The chilton's said remove the wheel assembly. Do i have to remove the calipers and rotors or can i just leave them on?
I'am not a mechanic but will try anything first myself before goin to stealershops.
snap2 is offline
post #2 of 4 (permalink) Old 07-18-2005, 07:40 AM
Cool
Changing a lower control arm on these cars isn't that difficult, but you do need to have some knowledge of how front ends (alignment, suspension) work, and work together. Go to your local Pep Boys and buy the Haynes Manual that is for the '89-'97 T'bird/Cougar, The books # is 36086. It is vehicle specific. Good luck
Uncaged 94 is offline
post #3 of 4 (permalink) Old 07-18-2005, 08:39 AM Thread Starter
I do have the haynes at home, i'll take a look at it this evening and compare that part with the chiltons in which i favor.
snap2 is offline
post #4 of 4 (permalink) Old 07-18-2005, 11:12 PM
you can keep your rotors and calipers on, they'll be attached to spindle which is still attached to tie rod and upper control arm.
XR7kid is offline
