rear control arm bushings split - TCCoA Forums
post #1 of 3 (permalink) Old 07-21-2005, 02:26 PM Thread Starter
I was washing the sand out from under my car (drove on the beach what a mess) and I noticed that there are some rubber bushings that are split and grease was oozing out on both sides on the rear lower control arm. It is a little arm about 10 inches long that is running next to the main rear lower control arm.
I cleaned the dirt (and sand) out and put some fresh grease on the busted rubber bushings. I hope this problem is not a similar problem like that occurs on the front upper A arm. It looks like major work to replace these bushings. Any suggestions?
W.Cup is offline
post #2 of 3 (permalink) Old 07-22-2005, 09:17 AM Thread Starter
I would recommend to all readers to get under your car and check this problem out and BTW, it is not easy to find. I hope this problem is not as potentially dangerous as when the front A arm bushings crack allowing dirt and water to enter, then the ball joint failing and finally the wheel comming off. Maybe my car is the only one with this problem.
W.Cup is offline
post #3 of 3 (permalink) Old 07-22-2005, 03:15 PM
I take it your talking about the rear sway bar bushings those are an easy replacement and i believe if they do happen to brake it wouldnt cause you to loose control just a wavey back end
MattsLE97 is offline
